Journal bearing simulation using ANSYS FLUENT
Like Tree1Likes
  • 1 Post By jsm
Old   September 1, 2020, 05:25
Default Journal bearing simulation using ANSYS FLUENT
zuraidah rasep
zuraidah rasep is on a distinguished road
Hye all;
As per attached was my graph validation for plain journal bearing by using engine oil (SAE20W40), Yellow graph is my data which i run by using CFD ANSYS FLUENT whilst the red graph is an experiment data. As the validation part, I need to validate the simulation data with the experiment data. Any idea on which parameter that i need to adjust (either FLUENT part or journal bearing part) so at least I get similar or at least error less than 10%. Or the graph already ok. Need suggestion from an expert here.Thanks again
zuraidah rasep is offline   Reply With Quote
Old   September 2, 2020, 02:26
jsm
JSM
jsm is on a distinguished road
I am not Journal Bearing Expert. So consider my ideas as options in simulation point of view.
You can try with refined mesh. Also temperature dependent properties might help to improve the accuracy.
zuraidah rasep likes this.
With regards,
JSM
jsm is offline   Reply With Quote
Old   September 2, 2020, 03:46
zuraidah rasep
Thank you sir for your suggestion.will try it.
Old   June 2, 2021, 09:39
Mehdi
Munte07 is on a distinguished road
Hi Zuraidah
May I ask you, how did you find the equilibrium position of the journal? Did you use any UDF?
Thank you
Munte07 is offline   Reply With Quote
2D or 3D simulation of particles in ANSYS FLUENT Mostafa Barghash FLUENT 0 November 30, 2019 10:13
ANSYS Fluent Sloshing in baffled tank simulation Fisya CFD Freelancers 2 August 27, 2019 18:55
Box Solar Cooker Simulation in Ansys Fluent Mahmoud67 FLUENT 0 November 9, 2018 00:56
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
ANSYS Multiphysics Bearing Simulation Dimitris ANSYS 2 November 10, 2011 06:17
