How to input mass flux(kg/mēs) of a species on the boundary |
August 9, 2020, 09:20 |
THA SEANGHAI
Rep Power: 5 |
Helllo! I am really struggling with using ANSYS FLUENT, I input x-velocity of air from inlet and I want to input mass flux or molar flux of a species on a boundary , but there are only some options such as mass fraction, mole fraction or we can write expression in the new verson of fluent that we can input molar concentration (kmol/mģ), but there is no the option for the mass flux(kg/mēs) or molar flux(kmol/mēs). How can I do? Or do i need to write UDF? I never learn code programming before, so UDF is really difficult for me.Please help me! I do not know how to do now! Thank you!
August 10, 2020, 01:19 |
Alexander
Rep Power: 34 |
in Fluent there is mass-flow-inlet boundary condition
Unit is kg/s If you want to define mass-flow-inlet as mass flux(kg/mēs) you need to multiply your mass flux value on area of inlet kg/mēs * mē = kg/s to get area you may do: press initialize reports-> surface integrals -> report type: area | select your inlet -> compute
best regards ****************************** press LIKE if this message was helpful |
August 10, 2020, 04:41 |
THA SEANGHAI
Rep Power: 5 |
Thank for your reply, but my purpose is just to input the mass flux of a species without velocity, if I chose the mass flow inlet BC, it will include velocity. I knew that mass flux depends on velocity, and it also depends on the diffusion coefficient of a species. In my case mass flux of a species= -Diffusion coefficient*concentration gradient. I mean that I want my species spreading out to the whole domain by diffusion coefficient, not by velocity. Thank you! Do you have any idea that I can input the mass flux of a species on a boundary without velocity? I will appreciate your help!
August 10, 2020, 05:37 |
Alexander
Rep Power: 34 |
had never made it before, but you may try:
1. Once species model is ON, you may specify mass source [kg/m3 s] and concentration 2. You may create very thin volume (but take care about mesh quality) , so you will get almost flux, not volumetric source -> [kg/m2 s] I don't know other ways, but definitely there should be
August 10, 2020, 21:05 |
THA SEANGHAI
Rep Power: 5 |
Thank again for your reply! Yes, I already input the concentration once the species model is on. I cannot input the concentration directly, because there is only two options that we can input in the species, they are mass fraction and mole fraction, however in the New version starting from ANSYS 18.0 up, there is an expression of mass fraction that we can write the amount of concentration instead of mass fraction only, because we know the relation between mass fraction and concentration that mass fraction=((molar weight of the component*molar concentration)/(mixture density)).
But one thing that I am really curious about is that: when we input the concentration on a boundary, so will ANSYS FLUENT calculate the mass flux automatically by computing the concentration from the equation that ANSYS has? If so, I do not need to write mass flux on the boundary, I just input the concentration and then calculate mass flux from the equation. Do you have any idea? Thank you! |
September 16, 2020, 10:04 |
#6 | |
THA SEANGHAI
Rep Power: 5 |
Another one problem that I realized is that even though I add mass source or not, the results of my species are still the same, is there something wrong in my program or not? Note that: to add source to the cell, I just input the constant value, not UDF, so because of being no UDF that make the results not effected? Thank you! I will always appreciate your help! |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
