Experience with 9 coefficient Janaf model modeling specific heat capacity
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   August 7, 2020, 04:39
Default Experience with 9 coefficient Janaf model modeling specific heat capacity
CFDger is on a distinguished road
I am modeling hypersonic air flow at Ma=7.9 and expect the total temperatures to be around 12000K (without considering chemical reactions). I always used the 7 coefficient polynomials for modeling my specific heat cp(T). But these polynomials are only valid up to 6000K. I am not sure whether FLUENT extrapolates values outside of this area or if it assumes a constant cp.
I have seen that the newer 9 coefficient polynomials can be fit up to 20000K. For the species O2, N2, O, N, NO I have gotten the coefficients which are valid for a max. temp of 20000K. But the one for air is apparently still only valid for a max temp of 6000K.
This is the link which provides the 9 coefficient polynomials:
https://www.grc.nasa.gov/WWW/CEAWeb/ceaThermoBuild.htm
Does anyone have experience with modeling air in such flight conditions?
Later on I plan to implement chemical reactions with which the maximum stagnation/total temperatures shoud be no higher than 7000K. So I don't think this should be an extreme problem at that point. But for initialising my problem I would like to start without chemical reactions and with air as fluid.
Fluid conditions:
Ts=1113K, ps=1824Pa, rho=5.71E-3kg/m^3
Thank you very much!
CFDger is offline   Reply With Quote
Old   August 7, 2020, 05:09
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
do you expect to get these properties in open source?
use linear (or any other) extrapolation for range above 6000K
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 7, 2020, 06:15
Well, yes until now I did. Why should I not expect to get those properties in open source?
Could you or sb else explain me how to set this up in the FLUENT settings (linear extrapolation for range above 6000K)?
Thanks!
Old   August 7, 2020, 09:29
Alexander
in fluent there is an option to use piecewise-linear properties.
you can use it.
For values above 6000K look at graph trend and based on your expectations extrapolate curve there
best regards
Old   August 19, 2020, 03:56
Another question which you or somebody else might be able to answer:
The standard 7 coefficient cp(T) polynom has the form of a classic polynom:
cp/R = a1+a2*T+a3*T^2+a4*T^3+a5*T^4
This is easy to implement in FLUENT as you mentioned.
But the 9 coeffcient cp(T) polynom has a different form:
cp/R = a1/T^2+a2/T+a3+a4*T+a5*T^2+a6*T^3+a7*T^4
Do you have to write an UDF to be able to implement this kind of "polynom" or is there a different way in ANSYS FLUENT?
Thanks
Old   August 19, 2020, 04:41
Alexander
I think, UDF is the only option.
on the other hand, you may use piecewise-linear option
CFDger likes this.
best regards
Old   May 4, 2022, 15:17
Seyed Saeid Nabavi is on a distinguished road
hi dude
sorry, can i have that 7 coeff polynomial for air cp? i need cp(T) up to 6000k.
Seyed Saeid Nabavi is offline   Reply With Quote
compressible, fluent, hypersonic, polynomial, specific heat
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Radiation Modeling Chris89 CFX 20 August 14, 2014 08:51
Effects of specific heat capacity modification - fluid/solid mesh simplifications Martin_D Main CFD Forum 0 January 30, 2013 07:24
error message cuteapathy CFX 14 March 20, 2012 07:45
