FLuent: Divergence in time-varying velocity inlet boundary condition
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   August 3, 2020, 03:22
Default FLuent: Divergence in time-varying velocity inlet boundary condition
sajjan
sajjan is on a distinguished road
Hello Fluent users,
I am trying to simulate a heat transfer phenomenon in a pipe. I apply velocity-inlet and pressure-outlet as the inlet and outlet boundary conditions respectively.
Nature of problem is that the velocity and the temperature at the inlet changes with time. It is not periodic either. I use a transient-table to define inlet velocity and tempetature profile.
I tried with different solution schemes available in fluent, changing relaxation factors, using small time-steps, etc. But the continuity diverges all the time. Even with small change in inlet velocity has a huge impact in continuity residuals.
I wonder if anyone has gone through a similar situation before.
Many thanks!
Sajjan
sajjan is offline   Reply With Quote
Old   August 3, 2020, 03:33
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
there are too many reasons which could lead to divergence
most likely your mesh is not good enough
check material properties and models you are using
check other boundary conditions
are you able to get converged solution in case of steady state boundary conditions?
sajjan likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 3, 2020, 04:12
sajjan
Hi Alex,
Thank you so much for the reply. My mesh quality is very good. Its a pipe flow and I generated the mesh using ICEM with O-grid. Even a worst element has a quality above 0.7. In addition, flow is perfectly aligned with the mesh. And yes, the flow gets converged with fixed inlet velocity and temperature. So, I believe, there should not be a problem with material properties or other boundary conditions.
The problem is, continuity residuals increase alot and ultimately the solution diverges with floating point error, even with a small change in the inlet velocity.
Thank you.
Old   August 4, 2020, 03:50
Alexander
check your mesh size, are you sure you are using proper units?
small changes in BC condition should not affect that match in case of flows in pipe
definitely you have problem in setup (check material properties, if they are not default)
best regards
continuity convergence, time-varying-vel-inlet
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
