How to calculate DPM particle flow rate for a 2D axisymmetric case
Like Tree1Likes
  • 1 Post By vinerm
Old   June 22, 2020, 20:05
Default How to calculate DPM particle flow rate for a 2D axisymmetric case
Anshuman Sinha
Anshs is on a distinguished road
Given the 2D geometry with an axis, how do we calculate the flow rate?
Geometry: Screenshot 2020-06-23 at 4.20.09 AM.jpg Inlet : Screenshot 2020-06-23 at 4.20.23 AM.jpg
Surface injection = inlet (6 mesh grid points) , mass flow rate = 3.6513e-6 kg/sec , density = 1.6228 (kg/m3) , Such that wolume flow rate per grid point ( at inlet ) = 2.25 cm3/sec .
While applying the axisymmetric case, how will we be able to calculate net flow rate? Had it been a 3D case, I would have multiplied it with the total number of mesh points on the inlet surface. But how may this be in a 2D axisymmetric case?
Thanks
Anshs is offline   Reply With Quote
Old   June 23, 2020, 04:40
Default 2D axisymmetric
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
It does not matter whether it is 2D or 3D. It is always the number of mesh points - face centers in case of 3D, and edge centers in case of 2D.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 23, 2020, 06:38
Default total flow rate?
Anshuman Sinha
Okay, so the total flow rate will be? As you may see from the image there are 5 edges, so will this be equal to = 5* (flow rate of 1 point)
Another question is how will this map to the real case? As we have the axis boundary condition. Since the experiment is actual 3D, What flow rate should I consider in the experiment?
Will it be the same, flow rate= 5*(flow rate of 1 point)
Thank you.
File Type: jpg Screenshot 2020-06-23 at 4.20.23 AM.jpg (58.3 KB, 6 views)
Old   June 23, 2020, 08:54
Default Flow Rate
vinerm's Avatar
Vinerm
The flow rate applied for a particle injection is never per edge or per face; it is always total flow rate. Its division across faces or edges also depends on the user; it could be set to uniform or non-uniform. However, the flow rate, for discrete as well as continuous phase, in case of an axisymmetric simulation, has to be equal to that for full 2\pi region, i.e., equal to what you have in the experiment or the real scenario.
Regards,
Vinerm
Old   June 23, 2020, 10:23
Default experimental flow rate value?
Anshuman Sinha
The flow rate applied for a particle injection is never per edge or per face; it is always a total flow rate. Its division across faces or edges also depends on the user; it could be set to uniform or non-uniform. However, the flow rate, for discrete as well as the continuous phase, in case of an axisymmetric simulation, has to be equal to that for full 2\pi region, i.e., equal to what you have in the experiment or the real scenario.
I wanted to know that while I'm using this setup Screenshot 2020-06-23 at 6.45.44 PM.jpg at the inlet, how may I find the volume flow rate of the gas which it would correspond to in the actual experimental setup?
given dpm particles (argon gas) density = 1.6228 gm/cm3.
mass flow rate = 0.01 kg/sec
inlet & geometry = already shown in the previous reply above. ( 30 mm in length with 5 edges in the mesh and axisymmetric condition )
With all this information how will I be able to find the volume flow rate which I will set in my experimental setup?
Thank you.
Old   June 23, 2020, 10:32
Default Volume Flow Rate
vinerm's Avatar
Vinerm
Volume flow rate is independent of particles or droplets. It is ratio of mass flow rate and density. So, 0.01 / 1.6228. The density value is correct, but the units you mentioned is wrong. The volume flow rate calculated is for full, circular duct.
Regards,
Vinerm
Old   June 23, 2020, 11:16
Default calculations
Anshuman Sinha
so it comes as (0.01 kg/sec / 1.6228 kg/m3 ) = 0.0061621888 m3/sec that is 0.0061 * (1000 * 60 ) = 369.73 lt/min.
Will this be the flow rate I would be required to set in the experimental inlet, which is a circular pipe of diameter 60 mm?
May you please have a look at the above pictures for reference.
Thank you for all the help.
Old   June 23, 2020, 17:14
vinerm's Avatar
Vinerm
Where does 1000 come from? Is it the density of the continuous phase?
Do note that axisymmetric model is valid only for the central inlet.
Anshs likes this.
Regards,
Vinerm
Old   June 23, 2020, 17:39
Anshuman Sinha
1 m3 to 1000 litres. yes for central inlet only. is it right?
axis boundary, discreet phase modeling, dpm, fluent
Exit Corrected Mass Flow Rate Mesh Sensitivity Study s__s__s CFX 4 July 20, 2016 12:46
How does Fluent works in DPM, with steady flow and unsteady particle tracking ? pkp FLUENT 2 March 30, 2016 18:38
Mass Flow rate in DPM model tohidtkz FLUENT 0 November 7, 2015 05:13
DPM total mass flow rate yow FLUENT 0 July 17, 2015 13:01
DPM mass flow rate Szabolcs Varga FLUENT 3 May 6, 2004 16:21
