chemical reaction in Fluent involving gaseous reactants and solid product |
June 21, 2020, 05:03 |
sara
Rep Power: 6 |
I am simulating a system involving four successive chemical reactions. Three reactions are involving gas to gas transformations. The last one has gaseous reactant and forms a solid and a gaseous product. The solid is in a powder form. I am using species transport as species model with volumetric reactions. I defined my solid as a fluid with solid proprieties. Can it model this reaction properly?
June 21, 2020, 17:20 |
Solid as Fluid
If you model solid as fluid, then Fluent would expect required properties, since it has to solve Navier-Stokes equation for that fluid. You have to use DPM (would require UDF for nucleation to form particles) or Population Balance Model. If the concentration of the resulting particles is very less and the fluid properties could be considered as averaged properties, then you don't need to model heterogeneous reactions or nucleation. You can modify the fluid properties in the cells where solid is formed. You still have to use UDF for that.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
June 26, 2020, 06:06 |
sara
Rep Power: 6 |
Hello, thank you Vinerm for your response. The concentration of solid particle is less than 10% (volume), so I don't need to model heterogeneous reaction?
Regarding DPM, does it need an injection? because the solid is a reaction product, and I can’t specify where would it be produced (X-position, Y-position, X-velocity etc...) |
Set Chemical Reactions in FLUENT | Liufeng_ustb | FLUENT | 0 | March 26, 2013 11:18 |
