Reaction rates from FLUENT in CFD Post
Like Tree1Likes
  • 1 Post By vinerm
Old   June 15, 2020, 05:37
Default Reaction rates from FLUENT in CFD Post
Paulo SPS is on a distinguished road
Hi there,
I'm using CFD-Post to post process a reacting flow case from Fluent and the reaction rates, which normally appear in the for contour plotting in Fluent, do not appear in the variable list in CFD-Post. The only reaction variable it shows on the list, besides the concentrations, is the heat of reactions.
Is there a way to get the reaction rates from Fluent in CFD-Post?
Cheers
Paulo SPS is offline   Reply With Quote
Old   June 15, 2020, 06:22
Default Reactions Rates
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
You have to select those variables and write as cdat files from Fluent. Or post-process those in Fluent.
Paulo SPS likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
cfd - post, post procesing, reacting flow
how to get proper points location of geometry in CFD Post? teguhtf ANSYS 0 May 4, 2020 16:59
HOW TO SHOW TIME IN ANIMATION IN Fluent CFD POST niazgdc FLUENT 0 October 12, 2017 03:58
Separate Convective and Radiative heat transfer in CFD post using fluent as a solver Lemanes FLUENT 1 July 6, 2015 11:31
fluent & cfd post maziar ANSYS 0 May 17, 2015 17:44
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
