Grid spacing for turbulent flow
Like Tree1Likes
  • 1 Post By vinerm
Old   June 14, 2020, 23:58
Default Grid spacing for turbulent flow
cfdnewb123 is on a distinguished road
I have been reading papers on simulating turbulent flow but they are all vague with regards to grid sizing. I keep seeing 4*pi*delta x 2*delta or 2*pi*h x 4*h. Do I just take these algebras (e.g. delta/h) as 1? None of them assign a value for these algebras and thus, I am not sure what should I used.
cfdnewb123 is offline   Reply With Quote
Old   June 15, 2020, 06:55
Default Delta
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The \Delta itself has a definition. Usually, it is used to define non-dimensional grid spacing similar to y^+. In this definition, cell size in a particular direction is used instead of height of the first cell from the wall. A good practice is to maintain about 40 non-dimensional spacings in flow direction and half of those in transverse direction.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 16, 2020, 11:15
Thanks for the reply but I am still unsure. Can I just use delta=1?\
Or
(for brevity, I will write \Delta=D and \delta=d)
I was given Dx+=20, Dy+=5, Dz+=10, y+=0.5 and computation domain in 2d units as (pi) x (1) x (0.5*pi) with grid points 68 x 68 x 128.
From Pope(2000), delta equals to half height of rectangle channel. Thus, d = 0.5*(2d)*(0.5*pi)? This doesn't makes sense. And why is the domain written in terms of channel's half-width? E.g. http://cfd.mace.manchester.ac.uk/cgi...as32_rsol.html
Or
From this site (https://www.researchgate.net/post/Wh...uirment_of_LES),
Half height of channel along x, Lx=0.5*pi*d;
Dx+ = dx/Lx = dx/(0.5*pi*d) = 20;
dx = 40*pi*d;
dx*Nx = (20*pi*d)*68 = 2*pi*d;
This doesn't make sense and I think I still don't fully get the dimensionless wall units too.
I think my confusion is mainly the notation. How do I interpret this delta? Or does it not matter what delta is as long as my dimensionless value are consistent with what I used for delta?
Old   June 16, 2020, 11:31
Default Notation
vinerm's Avatar
Vinerm
Forget about the notation. All you need to do is calculate x^+, just like y^+. And then you need to ensure that this value is equal to 20-40 when size of the cell is used in the definition.
In terms of channel height, H, and N_x and N_z being number of cells in the streamwise and transverse direction, you need to ensure that grid sizes \Delta x and \Delta z follow the relations
N_x = \frac{16H}{\Delta x} \\
N_z = \frac{6H}{\Delta z}
Across the height, maintain about 120-140 cells.
Regards,
Vinerm
Old   June 16, 2020, 12:18
However, what physical value should I assign to H in terms of metre?
delta = H / 2;
x+ = x / delta;
dx+ = dx / delta = x+ / Nx;
dx = x / Nx;
Subbing in your equation,
dx = 16*H*Nx*Nz;
Nx and Nz are given while x is given in terms of delta(=0.5*H). Thus, my dx is given in terms of delta or H which means I am still stuck trying to determine value of H or delta?
I do have the number of cells given for H but but what value should I give it in terms of metre length? Or does it not matter what physical value I assign to it as long as the above relation holds? Additionally, may I ask where does 16 & 6 come from?
Old   June 16, 2020, 12:27
Default Channel height
vinerm's Avatar
Vinerm
Channel height is user's choice but is actually the defining variable in Reynolds number. For a fixed Re and fixed fluid, H gets fixed since that is used to define Re.
16 and 6 are not hard and fast values, rather based on best practices developed over the time as well as based on the assumption that the system is periodic. It also depends upon what energy scale do you want to resolve in LES.
cfdnewb123 likes this.
Regards,
Vinerm
Old   June 16, 2020, 13:27
Thanks so much! I now know how to set up my domain accordingly
grid, spacing, turbulence
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
Problem with grid convergence for turbulent flow around cylinder aakie OpenFOAM Running, Solving & CFD 3 November 13, 2018 05:39
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
grid spacing for supersonic flow Abhinand FLUENT 3 July 26, 2017 12:49
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 08:33
