June 11, 2020, 10:11 |
Bias factor on a radius
Francesco
Rep Power: 6 |
Hi everybody,
I'm performing a thermal analysis over a 2D disk surface. My aim is to refine the mesh along the radius of the disk in a specific way and bias factor is what i must use to do this task. The problem is that i cannot draw a line along the radius on the mesh in which i have to apply the bias factor tho. Any suggestion on how to do it? I think that the problem is quite trivial, but i just can't find a solution Thank you in advance. |
June 12, 2020, 10:18 |
Francesco
Rep Power: 6 |
Nobody can help?
June 14, 2020, 12:54 |
#3 | |
mCiFlDk
Rep Power: 6 |
I can't think in other way to do what you want to. I would use Spaceclaim or Design Modeler to divide my geometry into two parts with a simple sketched line, and there you can use the bias factor. Regards. |
June 18, 2020, 16:33 |
Francesco
Rep Power: 6 |
Thank you for reply mCiFlDk
[TurboGrid] Wind turbine: problem with the hub radius | MrDaimon | ANSYS Meshing & Geometry | 0 | March 12, 2015 09:12 |
Gas flow through a channel with sudden radius expansion | Blooper | SU2 | 4 | June 5, 2014 16:40 |
Sampling along a radius | djh2 | OpenFOAM Post-Processing | 2 | March 25, 2014 11:26 |
Meshing of a sharp edge orifice with a radius | Moose1231 | STAR-CD | 3 | December 6, 2011 16:32 |
How Bubble Radius is Found in Cavitation | Chris | Siemens | 7 | June 22, 2004 13:43 |
