Backflow in nozzle exit (combustion chamber with nozzle) |
Lee Jo
Rep Power: 6 ![]() |
Hi..
I'm modelling a 3d combustion chamber with nozzle...the operating pressure are very high and fuels used are CH4 and liquid Oxygen (cryogenic temperature) Inlets : 8MPa Outlet : tried both 0MPa and 101325 Pa Operating conditions: 6MPa I am getting backflow in the outlet and the setup diverges...my mesh is good and have no skewness at exit or inside chamber and nozzle..my mesh is fine.. I even tried long slender gradually increasing length mesh at outlet so that the backflows stop.. My outlet pressure outlet backflow specification: Normal to boundary... Anyone knows how to solve this...??!! |
It appears to be a compressible flow. Use value of 0 Pa as operating pressure and apply all boundary pressure values as absolute values. You may also want to choose non-reflecting condition at the outlet.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Lee Jo
Yeah..I'm using SRK real gas equations..my outlet is a pressure outlet and how do I set it as a non reflecting condition??
That option is available within boundary condition panel. Open pressure outlet and you will see Acoustic condition options.
Chamber non-premixed combustion pressure | Hawxliquid | FLUENT | 0 | March 16, 2017 12:37 |
High pressure on combustion chamber; high temperature residuals | cheet | Siemens | 0 | January 13, 2017 10:34 |
De laval Supersonic Nozzle Exit Mach number in CFX | bharath | CFX | 7 | December 19, 2014 02:44 |
Same CD nozzle exit velocities from differing inlet/outlet pressure differentials | lcthompson | SU2 | 0 | January 7, 2014 16:47 |
Combustion chamber calculation | Kirill | CFX | 0 | July 4, 2003 04:02 |
