Turbulent flow simulation in a long pipe
Like Tree2Likes
  • 1 Post By LuckyTran
  • 1 Post By duri
Old   June 5, 2020, 12:41
Default Turbulent flow simulation in a long pipe
Ali
ammarali311 is on a distinguished road
Hello.
I am working on a simple turbulent flow simulation in a long pipe of length 1m in ANSYS Fluent. The inlet Re is 12000 and inlet velocity is 0.76 m/s. The problem is that the continuity residuals after some iterations remain constant and do not decrease no matter how long you run the iterations. Other residuals decrease and eventually reach the tolerance criteria except the continuity. I have tried changing the viscous model, solution methods, relaxation factors but the continuity residuals never converge .....I am stuck in this loop for a whole month now and don't know what to do....Its only a simple straightforward simulation and i am so much confused ...Please can anyone help me about what am i doing wrong and what solution approach should i use?????
ammarali311 is offline   Reply With Quote
Old   June 5, 2020, 14:15
Lucky
It's probably fine. The continuity residual is scaled differently. If you reset the residuals and keep running the simulation, you'll find that the continuity residual will be stuck at 1.
ammarali311 likes this.
Old   June 5, 2020, 15:35
duri
duri is on a distinguished road
Continuity residual is normalized and dropped by two order which may be fine. May be absolute continuity residual is too small from beginning. Don't normalize or scale the residual and check. Other way of confirming the continuity convergence is through mass flux balance.
duri is offline   Reply With Quote
Old   June 5, 2020, 15:39
Ali
Thankyou for your replies...I will look into your suggestions
fluent, pipe flow, turbulence modelling
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
Erosion of turbulent flow in pipe claudy.daniel FLUENT 0 September 8, 2015 11:10
Time averaged velocity in turbulent pipe flow tsero FLUENT 1 November 2, 2012 04:19
FDTD Simulation of flow through tapered pipe Jim Main CFD Forum 3 December 25, 2006 11:56
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
