total heat transfer rate and total sensible heat transfer rate
Like Tree2Likes
  • 1 Post By Weiqiang Liu
Old   June 5, 2020, 09:02
Default total heat transfer rate and total sensible heat transfer rate
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I am doing a combustion simulation with fluent. when determining convergence, I checked the flux report and tried to checked energy balance of the whole system.
There are two options to check. first is total heat transfer rate and the second is total sensible heat transfer rate.
I am wondering what is the difference of heat transfer rate and sensible heat transfer rate?
Best regards
Weiqiang
Phanindra Raavi likes this.
Weiqiang Liu is offline   Reply With Quote
Old   June 5, 2020, 10:06
Default Heat Fluxes
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
For reacting flows, sensible heat transfer rate is not conserved. Therefore, you should look at total heat transfer rate. These details are given in User Guide.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 5, 2020, 10:12
Weiqiang Liu
Hi, Vinerm,
Thanks very much. Your reply is really helpful!
Best regards
Weiqiang
Old   June 5, 2020, 10:53
Weiqiang Liu
Hi Vinerm,
I just checked the user guide of ansys. sensible heat transfer rate excludes reaction enthalpy and reaction enthalpy is illustrated separately. Therefore sensible heat transfer rate adding with reaction enthalpy is conserved, right?
Weiqiang
Old   June 5, 2020, 12:05
Default Flux
vinerm's Avatar
Vinerm
Yes, that's correct. But if the species and/or energy equations are well converged, then both will show a small number and could be used as convergence criteria.
Regards,
Vinerm
Old   June 5, 2020, 21:59
Weiqiang Liu
Hi Vinerm,
Thanks very much! my problem is: monitored value, species profile or contour are steady. however, total heat transfer rate or sensible heat transfer rate are oscillating. Sometimes they are tens of W and sometimes they are close to 0.
I am wondering how can I avoid this phenomenon. Because I am really not very sure whether the case is converged when energy balance is oscillating.
ps: I have both gas phase and surface phase mechanism in my case.
Best regards
Weiqiang
energy balance, heat transfer rate, sensible heat transfer
Problem with total heat transfer rate aswathy_raghu FLUENT 9 April 21, 2022 11:36
Problem with total heat transfer rate aswathy_raghu FLUENT 0 July 26, 2016 08:39
Total Heat Transfer Rate & Total Surface Heat Flux Mismatch icaro FLUENT 0 November 24, 2009 08:01
Inconsistent Total Heat Transfer Rate Ken Adams FLUENT 0 July 24, 2007 12:04
Help! Total heat transfer rate doesn´t sum to zero Thomas FLUENT 0 April 6, 2005 03:55
