turbulent kinetic energy and turbulent dissipation rate |
June 4, 2020, 20:25 |
shayan
Rep Power: 8 |
hi. I am simulating flow around hydrofoil with K Epsilon method (realizable)
in boundary conditions and inlet, there are two parameters : turbulent kinetic energy and turbulent dissipation rate how can I determine proper magnitudes for these two parameters? |
June 5, 2020, 02:55 |
Turbulence at Inlets
The relevant information is available in Fluent's User guide
https://www.afs.enea.it/project/nept....htm#ke-params
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
June 5, 2020, 05:56 |
shayan
Rep Power: 8 |
I had seen this user guide before but I don't know how to calculate u' and uavg
can I use equations 1 and 2 and approximation table in below paper for my case? https://www.simscale.com/forum/t/def...nditions/80895 |
June 5, 2020, 06:02 |
RSM and Average
Average velocity is the velocity at the inlet. As far as is concerned, you have to assume, say 5% or 10% of average velocity. You can use the data from the table.
June 5, 2020, 06:09 |
#5 | |
shayan
Rep Power: 8 |
and I have another question. in user guide there is a formula for length scale l which is l=0.07L what is L for my case? is this chord length of hydrofoil? K and epsilon are independent from directions of inlet velocity (vx and vy) and only depends on magnitude of inlet velocity? |
June 5, 2020, 06:19 |
Yes
Answers to all your questions is a yes.
June 5, 2020, 06:21 |
shayan
Rep Power: 8 |
thanks a lot. you have helped me these days a lot.
Calculation of Turbulent kinetic energy and turbulent dissipation rate | Mondal131211 | OpenFOAM Pre-Processing | 1 | October 13, 2019 21:29 |
Default values of turbulent kinetic energy and turbulent dissipation rate | Manu4CFD | FLUENT | 16 | August 1, 2019 09:08 |
how to define the turbulent kinetic energy and turbulent dissipation rate? | fanke | FLOW-3D | 4 | March 26, 2013 20:40 |
turbulent kinetic energy and turbulent dissipation rate | D_L | Main CFD Forum | 5 | July 17, 2010 02:35 |
turbulent kinetic energy and dissipation | panneerselvam.R | CFX | 1 | July 22, 2005 01:55 |
