Weiqiang Liu
Rep Power: 9 ![]() |
Hi all,
I am doing a reacting flow with fluent. While iterating, fluent will complain a warning: dasac failure at temperature continuing. However, iteration can continue without error. I am wondering why would this happen? will this effect final calculated results? Best regards Weiqiang |
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
#3 | |
Weiqiang Liu
Thanks very much for the sharing. Best regards Weiqiang |
Garikai Marangwanda
Rep Power: 12 ![]() |
From my experience with the error, here are my thoughts:
1. Try making the mesh courser, I read somewhere that the easiest way to fix the error is to fix your mesh (avoid unnecessary refinement), 2. If fixing the mesh is not an option, look into the turbulence models, usually a model that allows near-wall treatment options to be used can do the trick, 3. My go-to option personally is to shy away from mass flow inlet boundary specifications but rather perform necessary calculations so they become velocity inlets. I hope this helps someone. |
dasac failure, mechanism, reacting flow |
dasac failure at Temperature | Leverkin | FLUENT | 5 | July 31, 2020 00:04 |
Oxy-Fuel combustion dasac failure | Pat84 | FLUENT | 3 | November 15, 2018 03:42 |
heat transfer coefficient value in floefd | jason kid | FloEFD, FloWorks & FloTHERM | 10 | October 16, 2016 16:55 |
dasac failure at temperature=999.97: continuing | deco | FLUENT | 1 | June 17, 2014 09:38 |
Dasac failure at 400K COPROX | elmcmaster | FLUENT | 0 | October 20, 2010 10:23 |
