post-processing of the .cas.h5 files saved by fluent 2020 |
June 1, 2020, 05:21 |
志新高(Zhixin Gao)
Rep Power: 12 |
I did some transient work using fluent 2020, and the format of the autosave files was .cas.h5. When I planed to do some post-processing work using CFDpost, I found that the .cas.h5 files could not be opened. I also tested Tecplot, it could not open the file either. So I was wondering how can I do the post-process work (Besides save the file as .cas). Any help will be great. Thanks. |
June 2, 2020, 09:42 |
Case File
Case file only contains mesh and setup. Results are in data files. CFDPost may or may not be able to load HDF, but I'd expect Ansys to have made it possible. Else, write data file as dat.gz or export cdat from Fluent.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
June 5, 2020, 01:54 |
志新高(Zhixin Gao)
Rep Power: 12 |
Thanks for your reply. Now I have saved new files as the older format. Just wonder why Cfdpost does not support .dat.h5 format.
September 15, 2020, 14:43 |
Piotr Prusinski
Rep Power: 16 |
It's because EnSight does the job instead of CFDPost.
CFD-Post is coming to its end I believe, EnSight was bought just to fill this gap. |
September 15, 2020, 21:55 |
Dico Nico
Rep Power: 7 |
I've faced the same problem. So, that I know, you have two options, if your simulations don't take too long to finish, do them again and create a report for CFD post, or, you can load them in fluent and save in .cas, manually, wich is painfully boring.
March 28, 2021, 00:59 |
#6 | |
Alexander
Rep Power: 5 |
Is there a way to save the result files in simple cas and data files? please help. |
April 13, 2021, 21:00 |
Basil Hunter
Go to the File->Preferences in the “general” section, change the “Default Format for I/O” from “CFF” to “Legacy”
And then when you write the .cas and .dat files make sure to select the “.cas and .dat” option, and not the CFF format with .cas.h5 and .dat.h5 |
April 20, 2021, 14:56 |
Scott Fowler
Rep Power: 17 |
At Tecplot we've just released our Tecplot 360 2021 R1 Beta which includes support for the Ansys Fluent CFF (.cas.h5/.dat.h5) format. The official release should happen by mid-May 2021.
Visit www.tecplot.com and go to the "My Tecplot" link to download the Beta. This requires a portal account, which is free. Let me know how the loader works for you! Thanks, Scott Fowler Tecplot 360 Product Manager |
June 29, 2021, 06:50 |
This is the solution to the problem.
#9 | |
ROBIN
Rep Power: 6 |
This is the solution to the problem. Thank you very much! |
September 24, 2022, 07:41 |
#10 |
Shrutika
Where can I find file--> preferences to change the default format?
Is it in the fluent? |
September 24, 2022, 07:53 |
Go to my video on this
#11 |
ROBIN
Rep Power: 6 |
Here is a link to do so. The same I created to tackle this issue.
https://www.youtube.com/watch?v=uN09vQgkslI&t=81s |
September 24, 2022, 07:55 |
#12 | |
ROBIN
Rep Power: 6 |
October 13, 2022, 05:47 |
[Fluent]convert .h5 to .dat, postprocessing using CFD-POST
#13 |
Hsingtzu Wu
Rep Power: 15 |
I found a way to convert .h5 to .dat, which is accepted by CFD-POST.
I will explain with an example, say there are two files, FFF.gz.cas.h5 and FFF.gz.1.dat.h5. 1. Open “FFF.gz.cas.h5” using Fluent 2. File>Read>Data, choose “FFF.gz.1.dat.h5” 3. File>Write>Case and Data, choose where you like to save the files and click “OK” 4. Repeat 2. and 3. as needed 5. Open CFD-POST 6. Load Results file, choose either “FFF.gz.1.dat” or “FFF.gz.1.cat” to do postprocessing |
December 30, 2022, 14:38 |
Fluent 2020-R2 mesh type error, Tecplot
#14 | |
Rep Power: 3 |
When I export the data as Tecplot it gives an error as "Zone ID 18 in file "file.cas" has no nodes." I used Watertight Geometry mesh type in 3D. I couldn't get any images from the Tecplot. I've tried to save it with all kind of formats (including Ensight), however generally it gives an error about the mesh type "polyhexcore". Has anyone encountered this error? |
January 3, 2023, 12:49 |
#15 |
Scott Fowler
Rep Power: 17 |
zemfahs,
Are you able to use Tecplot 360's Fluent CFF (*.h5) data loader to load cas.h5/dat.h5 files directly? This data loader was introduced in Tecplot 360 2021 R1 (May 2021) Thanks, Scott |
January 8, 2023, 15:10 |
#16 |
Rep Power: 3 |
Thanks for answering wsfowler,
My fluent (2020 R2) doesn't save as .cas.h5 or dat.h5. It saves as .cas and .dat. I also tried Tecplot 2022 version but it didn't work. I have a 3D model in ANSYS 2020 R2. I ran it and got my results which were correct. But when I save my analysis as TEC file and try to open it with Tecplot 360 it looks like 2D. Then when I select 3D Cartesian it opens but this time Iso-Surfaces is passive. As far as I understand, the program assumes that my file is 2D. Because the program only sees the models sides, top, bottom, inlet and outlet. it can not see interior. Then as a second way, I saved the data as .cas and .dat to open the file in Tecplot. However this time in Tecplot there is another error message for me 'Zone ID 44 in file "file.cas" has no nodes.' |
January 11, 2023, 18:24 |
#17 |
Scott Fowler
Rep Power: 17 |
My understanding is that Ansys Fluent only exports the surface data when writing to Tecplot format. Tecplot 360 will load this data in 2D mode since there are no volume elements in the dataset. You can flip to a 3D view using the Plot Type control at the top-left of the user interface.
I'm concerned though that Tecplot 360 is having problems loading your .cas and .dat files. We should be able to load these files. If you're able to share your data with our support staff, that would be ideal - perhaps there's an issue with our data loader. Please contact support@tecplot.com. Thanks, Scott |
June 7, 2023, 02:18 |
#18 |
Abbas Dorri
Rep Power: 3 |
very nice. My problem was also solved.
August 18, 2023, 05:25 |
loading transient saved .dat.h5 to cfd-post
#19 |
sai
I have a problem with loading the saved sequences all to the cfd post to have the evolution in time... it doesn't load it as all saved data files and keeps them all seperated. also, i chose the option to keep it as single case
How can I get a variable as output parameter from A UDF for post processing in fluent | Oula | Fluent UDF and Scheme Programming | 9 | November 2, 2018 05:35 |
post processing with Fluent | Ema40 | Fluent Multiphase | 0 | October 14, 2015 12:47 |
Post processing slice files for periodic pipe flow | Dan1788 | Tecplot | 3 | December 16, 2014 19:26 |
Need help in post processing of Slurry flow in Ansys Fluent | jatin1990 | FLUENT | 0 | November 5, 2014 14:11 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
