oscillation in residuals and force coefficients plots |
shayan
Rep Power: 8 ![]() |
I am simulating flow around 2D hydrofoil in ansys fluent.
I am doing this for various angle of attacks between 0 to 20 degrees. the results are ok until 12 degree but after that residuals and lift and drag coefficients plots became oscillating. how can I solve this problem? for more information: the model is k-epsilon (realizable and standard wall functions). scheme is coupled and gradient option is green-gauss cell based. pressure, momentum, turbulent kinetic energy and turbulent dissipation rate are chosen second order. |
Beyond 12 degree AoA, it is quite possible that the boundary layer is separating. If that is the case, then you cannot use standard wall function; it is not applicable for even slightly separating flows. So, you have to refine the mesh to maintain
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
shayan
Wall Yplus is available under Turbulence category. You can plot its contours or xy-plot on the wall of the hydrofoil.
Why did the residuals increase after flattened out as I continued the iteration? | pchoopanya | ANSYS | 2 | April 24, 2024 21:34 |
Interesting force oscillations in 0g VOF slosh case | spaceprop | OpenFOAM Running, Solving & CFD | 5 | January 25, 2021 13:22 |
Local spikes in force coefficients | sjsivabharathy | OpenFOAM Running, Solving & CFD | 0 | May 1, 2019 14:14 |
Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 10:42 |
Setup/monitor points of pressure and force coefficients | siw | CFX | 3 | October 22, 2010 06:07 |
