conjugate heat transfer - Temperature limited to 5000 K in solid volume
Like Tree1Likes
  • 1 Post By vinerm
Old   May 28, 2020, 11:59
Default conjugate heat transfer - Temperature limited to 5000 K in solid volume
Nicolas
nvalencia is on a distinguished road
Hi all,
I've been trying to generate a cooling plate conjugate heat transfer model (for battery cell cooling). It consists of a plate which has two cooling channels in it (water), as seen in the mesh photo attached. I generated the grid using Pointwise, with an average element size of 0.5 mm (the plate is 1 mm thick). My input is a constant heat flux at the bottom wall of the plate (820 W/m^2).
When I run the simulations, after a few iterations I get the message of temperature limited to 5000 K in the solid region. I don't think the issue is the mesh as it is well refined. Also, it seems as if heat is not being transferred into the cooling channels, as their temperature is not changed.
If someone has an idea of what the issue can be I would appreciate it, or if someone has used Pointwise to mesh these type of problems, as it could have to do with the way the BCs are assigned there.
Thank you.
nvalencia is offline   Reply With Quote
Old   May 28, 2020, 14:01
Default Mesh
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
If the plate is 1 mm thick, then the maximum cell size should be no more than 0.25 mm. You need minimum four cells across the thickness. And it appears that you are solving only conduction. So, you don't need such a fine mesh. A coarser mesh along the width and length will do, but along the thickness, maintain at least four cells.
nvalencia likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 29, 2020, 07:07
Nicolas
Hi Vinerm,
Thank you very much. I tried that and it fixed the problem.
Regards,
Nicolas
Old   May 29, 2020, 07:23
Default Good
vinerm's Avatar
Vinerm
Nice to know that. It is the requirement of FVM to have at least three cells between any two boundaries.
Regards,
Vinerm
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
