How to plot turbulent shear stress in Fluent post processing?
Like Tree1Likes
  • 1 Post By vinerm
Old   May 26, 2020, 13:28
Default How to plot turbulent shear stress in Fluent post processing?
cfdnewb123 is on a distinguished road
I want to plot a graph against turbulent shear stress u'v'. It is not the same as wall shear stress which option already exists and I have already plot that.
cfdnewb123 is offline   Reply With Quote
Old   May 26, 2020, 15:48
Default Reynolds Stress
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
What do you mean by Fluent Post-Processing? Is it within Fluent or CFDPost? If you are using Workbench and opened the tool using Results cell, then it is CFDPost. Reynolds stress is nothing but the turbulent kinetic energy, if you are using EVM. If you are using RSM, then it is directly available for plotting. So, it depends on the turbulence model being used.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 26, 2020, 22:04
Thanks for the response. Yes I am using CFDPost. However, when I try turbulence kinetic energy, it gives me result different from experiment. Is turbulence kinetic energy the same as turbulence shear stress? I thought TKE=0.5 u'u' while anisotropic TSS=u'v'?
If EVM doesn't provide the TKE as you mentioned, I can define this field by myself. However, do you know where can I define the TSS on CFD-Post? It doesn't have Fluent's UDF.
Old   May 26, 2020, 23:29
Never mind. I resolve this already. Thanks
Old   May 27, 2020, 04:23
vinerm's Avatar
Vinerm
TKE is neither Reynolds stress nor it is 0.5u'^2, at least not for EVM. What I meant was that you can calculate it using k because Reynolds stress is \rho u'v' and k is based on (3/2)u'^2. However, for isotropic turbulence, Reynolds stress tensor has all its six components equal to each other. Therefore, you can determine it using (2/3)\rho k. Do note that this is magnitude and implies no direction. You cannot define k yourself since a conservation equation is solved for it and EVM always provides k (turbulent kinetic energy). In CFDPost, you need to define an expression and then assign this to a new variable.
cfdnewb123 likes this.
Regards,
Vinerm
Old   November 9, 2021, 05:45
whistling is on a distinguished road
Hi, I have to do the same thing. Could you please tell me how to do?
whistling is offline   Reply With Quote
fluent, shear stress, turbulence analysis
Export Wall Shear Stress Data trooken FLUENT 6 February 5, 2019 16:09
Cannot achieve negative wall shear stress values in CFD Post (ANSYS) SAtkins CFX 3 August 3, 2016 15:27
Wall Shear Stress: Ansys Fluent chowdhury FLUENT 3 November 17, 2015 01:09
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Plot normal and shear stress sagga FLUENT 2 July 15, 2005 01:46
