Flow Over UAV - Question about FLUENT Solver and Y+
Like Tree1Likes
  • 1 Post By vinerm
Old   May 9, 2020, 18:07
Post Flow Over UAV - Question about FLUENT Solver and Y+
Yael
Waketraveller is on a distinguished road
Dear All,
I have been trying to model turbulence on a mini-UAV as part of a project for my school. The problem is that I don't quite understand how to assess if the use of Y+ in my model has been correctly implemented.
I have used the Y+ Wall Distance Estimation for Y+ values of 30 and 1, getting 3.5e-4 m and 1.2e-5 m respectively for the estimated wall distance.
My objective is to accurately capture the CD coefficient for the entire UAV, I've read that the Y+ value depends on type of model, what I have is: Re = 2.1e+5, V = 25 m/s, Chord Line = 0.1255 m.
I have used K-epsilon Standard and Realizable Models with enhanced wall treatment for Y+=30 and K-omega SST for Y+=1 and I basically get the same drag and lift coefficients for both models, I don't know if instead of resolving the viscous sub-layer I should use wall functions.
Also, I had checked the velocity profile on my models and saw that the velocity doesn't rapidly change normal to the surface of the wing. Does that mean the model is grid independent?
Below I attach some images for the k-omega SST Model (Y+=1):
1.- Contours of Y+ from Post in Fluent
2.- XY Plot of Y+ for the UAV
Any help is greatly appreciated!
Last edited by Waketraveller; May 9, 2020 at 19:42. Reason: I didn't attach the images correctly
Waketraveller is offline   Reply With Quote
Old   May 10, 2020, 14:50
Default Wall Yplus
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The values for y^+ are in the expected range. So, you can trust the model as far as the mesh resolution is concerned. Accuracy depends on other aspects as well, such as, material properties, boundary conditions, discretization order, etc. But mesh is good.
Waketraveller likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Fluent Adjoint Solver? ex10148 FLUENT 16 September 28, 2018 09:11
Radiation Modeling Using Discrete Ordinates Method and Parallel Solver malicemethods FLUENT 3 May 25, 2018 15:25
Fluent Adjoint Solver for compressible flow b.shuvayan FLUENT 2 January 30, 2015 08:27
On Setring Step Size in unsteady Solver of FLUENT lzgwhy FLUENT 0 August 19, 2009 23:44
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
