May 6, 2020, 14:19 |
Flow is separating for 2D and not for 3D
Rep Power: 6 |
Hey, I'm analysing an automobile on Ansys and it has a tail extension at the rear. The problem is I'm getting a flow separation if I take a side view and perform an analysis 2D but I'm not getting a flow separation if I perform my analysis 3D. What might be the reason for this?
Please view the attached images for more information. P.S: I used k-omega for the analysis. |
May 6, 2020, 15:52 |
2D and 3D
A 2D planar essentially means planar, i.e., no variation of anything along the z-coordinate. In 3D, even if you maintain the assumption of no variation in geometry along the width, i.e., you maintain exactly same profile end-to-end going along the width, the end walls do not exist in 2D. The flow stays attached to these walls and make it different from 2D. And if the profile is not same, such as the case in real vehicles, then obviously, you don't expect the results to be same.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 6, 2020, 19:35 |
Lucky
Rep Power: 66 |
I see separation for both 2D and 3D. Why are you saying the 3D one is not separated?
May 11, 2020, 00:16 |
#4 | |
Rep Power: 6 |
May 11, 2020, 00:19 |
#5 | |
Rep Power: 6 |
In the first 2 images, there is a separation at the starting of the tail extension but for the 3D there is no separation or slightly separates at the end. |
May 11, 2020, 04:06 |
Alexander
Rep Power: 34 |
you may make "planar" geometry in 3D to check the difference between 2D and 3D
extrude your cross section
best regards ****************************** press LIKE if this message was helpful |
May 11, 2020, 07:57 |
Rep Power: 6 |
May 11, 2020, 11:21 |
Flow Difference
Yes, the difference would depend on many things, namely the mesh, the angle of the side walls (close to C pillar in case of a car or van) with respect to the vertical plane. As Alexandar suggested, if you want to compare, then create a mid-surface using Surface option in Fluent and plot the contours there. Assuming the mesh resolution is similar and both cases are well converged, the closest match with 2D would be at the central vertical plane of the vehicle.
May 12, 2020, 02:10 |
#9 |
Alexander
Rep Power: 34 |
May 13, 2020, 02:14 |
#10 | |
Rep Power: 7 |
Others have already pointed this out, but let me try to explain it from a physical point of view. When you carry out a 2-D planar simulation, you assume that the body that you are simulating does not end in the lateral direction, meaning, it extends to infinity. The implication of this is that when a low pressure region is built aft of the body, only the flow above and below the body can try to fill the low pressure region. But the flow has a certain momentum and cannot immediately fill the low pressure regions. Hence you see a separation. In the 3-D case, your body has a finite thickness. This means that the flow at the sides of the body also flushes inwards into the low pressure region at the aft part of the body. Totally, you have more flow trying to flush into the low pressure wake (i.e. flow from above and below and flow from the sides) The leads to a lower separation. Which is evident in the contours you posted. Of course as vinerm suggested the numerical results depend on a lot of different things. But considering that you've them them correctly, this is the physical explanation of the process. Hope this answer was useful NonStopEagle |
