UDF to check the volume fraction of secondary phase |
May 5, 2020, 17:45 |
shivam salokhe
Rep Power: 9 |
Hello Everyone,
I am trying to write a UDF code that enables us to check the volume fraction of the secondary phase in a given cell zone while using the volume of fluid method. Also, I need to store the related time value when the volume fraction of the secondary phase in a cell zone becomes 1. Total I have 4 different cell zones. Thanks, Shivam |
May 6, 2020, 01:34 |
Alexander
Rep Power: 34 |
read Ansys FLuent Customization manual,
look for VOF Multiphase Model Macro you may store the time moment when C_VOF == 1 into user-defined memory (however, it depends on why do you need it and how are you going to use these data)
best regards ****************************** press LIKE if this message was helpful |
May 6, 2020, 05:25 |
Checking volume fraction
As Alexander suggested, you can use C_VOF macro to fetch value of volume fraction for any of the phase. However, you need to decide about when do you want to run such a function. If you run it, say, every time-step, then it is possible that a cell is full of secondary phase at one time but only partially filled with secondary phase at next instant. So, you have to have a logic that you wish to use to assign a marker of 1 or 0. You will have to use User-Defined Memory to save this marker. One you are clear about this logic, code is fairly simple.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
fluent - udf - parallel, vof multiphase |
How to access the Phase volume fraction in Expressions | dinhanh | CFX | 2 | April 29, 2018 08:08 |
UDF for secondary phase volume fraction assignment | sirpolar | Fluent UDF and Scheme Programming | 0 | October 17, 2014 09:25 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
interDyMFoam - change in volume fraction | gopala | OpenFOAM Running, Solving & CFD | 0 | April 27, 2009 11:46 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
