Multiphase mass transfer conditions for a heat pipe |
April 23, 2020, 12:30 |
Rep Power: 8 |
I use ANSYS Fluent to simulate a heat pipe using VOF multiphase model. I used mass transfer condition from water(liquid) to the water vapor (evaporation), but as you know, after the fluid evaporates in a heat pipe, it will condense in the condensation zone. Should I also add the mass transfer condition from water vapor to water(liquid) (for condensation) to the mass transfer conditions? Regards. |
April 23, 2020, 15:50 |
Mass Transfer
If you are using inbuilt Evaporation-Condensation model, i.e., either Lee or Thermal Phase Change model, then you do not need to enable two mass transfer mechanisms since these models take care of both, evaporation and condensation. If you are using one of your own model via UDF or some other mechanism, then you might need to enable two mechanisms, depending upon the model you are using.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
fluent, heat pipe, multiphase |
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 33 | August 16, 2024 06:09 |
Conjugate Heat Transfer in rectangular pipe with cylindrical pins | PabloXX37 | System Analysis | 0 | November 20, 2019 10:46 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
