April 21, 2020, 22:10 |
Parallel Error Abnormal Exit!
Rep Power: 7 |
I am attempting to run ANSYS 2019 R1 Fluent in parallel on 8 cores but the simulation runs for 2 to 4 hours then Fluent disappears logging the following errors:
Error [node 0] [time 4/22/20 0:18] Abnormal Exit! Error [node 1] [time 4/22/20 0:18] Abnormal Exit! Error [node 2] [time 4/22/20 0:18] Abnormal Exit! Error [node 3] [time 4/22/20 0:18] Abnormal Exit! Error [node 4] [time 4/22/20 0:18] Abnormal Exit! Error [node 5] [time 4/22/20 0:18] Abnormal Exit! Error [node 6] [time 4/22/20 0:18] Abnormal Exit! Error [node 7] [time 4/22/20 0:18] Abnormal Exit! Error [node 999999] [time 4/22/20 0:18] Abnormal Exit! What could be the issue? I have attempted all the solutions suggested on this platform for problems that are almost similar but nothing seems to work. Thank you very much. Much appreciated |
April 22, 2020, 05:24 |
Error
This is very common error. However, if the case did not diverge or if there is no UDF that could be causing this, then most likely reason is the network. The network across multiple nodes is unstable. If it is a single computer with multiple cores, then it cannot be network but resource unavailability could still cause this issue.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
April 22, 2020, 07:59 |
Rep Power: 7 |
Thank you very much for your response. Much appreciated.
I run Fluent on a single computer with multiple cores, 4 cores,8 threads. Your hypothesis that it may be resource unavailability may be correct. Though I was able to deduce that this often occurred when the internet connection to the computer was interrupted. The last two simulations I ran, the computer was offline and the simulations were successful. This is just a theory, still uncertain if this is the actual root cause. |
April 22, 2020, 08:02 |
Internet Connection
Yes, the net connection disruption or connection changes the settings. So, that is the reason.
April 22, 2020, 10:20 |
Rep Power: 7 |
Doing another simulation run with the computer offline to see if there will be any issues.
Will do an update on the outcome. Again, thank you for your response, much appreciated. |
June 20, 2022, 06:56 |
Rep Power: 6 |
Hello Morice
Is the error due to a network problem or memory allocation? I have the same issue. Thanks |
abnormal exit |
[snappyHexMesh] Error while running SnappyHex in parallel | mg.mithun | OpenFOAM Meshing & Mesh Conversion | 1 | February 10, 2016 14:13 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 12:58 |
Running parallel case after parallel meshing with snappyHexMesh? | Adam Persson | OpenFOAM Running, Solving & CFD | 0 | August 31, 2015 23:04 |
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing | Regis_ | OpenFOAM Meshing & Mesh Conversion | 2 | June 4, 2015 14:44 |
