Solving Maxwell's eq using UDF
Like Tree1Likes
  • 1 Post By vinerm
Old   April 11, 2020, 12:03
Default Solving Maxwell's eq using UDF
gdhamale
gdhamale is on a distinguished road
Hi there,
I am learning to write a UDF for plasma torch simulation (DC arc). Pl help me to understand how to write udf to solve coupled equations (attached) for my computational domain
J (current density) is known to us and defined via DEFINE_PROFILE macro (boundary condition given at the surface of a cathode) as below:
#include "udf.h"
double Rc 0.0002 /* Arc cut radius in meter*/
DEFINE_PROFILE(Current_den,t,i)
face_t f;
double x[ND_ND],J0,b;
begin_f_loop(f,t)
F_PROFILE(f,t,i)=0.;
F_CENTROID(x,f,t);
J0 = 5.7e8;
b = 2935;
if(x[1]<= Rc) F_PROFILE(f,t,i) = J0*exp(-b*x[1]);
end_f_loop(f,t)
Last edited by gdhamale; April 11, 2020 at 12:08. Reason: Not showing the attachment
gdhamale is offline   Reply With Quote
Old   April 11, 2020, 14:19
Default Maxwell Equations
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Your query is not very clear. As far as solving of an equation is conserved, then you have to enable an equation for a scalar. If you wish to use inbuilt MHD model for your application, then equation is already being solved, though with certain assumptions.
As far as the UDF is concerned, it will return a value and apply that value to whichever variable you hook it. If you hook it for current density, then it will be taken as current density. If you hook it for potential, then it will be used as potential.
gdhamale likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 11, 2020, 14:56
gdhamale
Thank you for your response.
Yes, I need to enable the scalar equation (for vector and scalar potential – total 3 equations in 2D) which I have mentioned in the attached image. Could you pl explain me how to express these equations using DEFINE_SCALAR macro?
Thanks a lot!
Old   April 11, 2020, 16:21
Default MHD Module
vinerm's Avatar
Vinerm
I'd suggest you to have a look at inbuilt MHD module.
https://www.afs.enea.it/project/nept...d/main_pre.htm
If you want to use your own equations, then you just need to enable scalars under User-Defined > Scalars. This is done via GUI not via a UDF. However, UDF might be required if you want to specify something special, such as, a constitutive relation or boundary condition.
Regards,
Vinerm
Old   December 4, 2020, 03:25
Smile
Aditya Shaw
shawaditya is on a distinguished road
Hello, I am doing a similar simulation in plasma and was wondering if you were able to solve the maxwell udf issue. I'd be extremely delighted if you could help me out
Thanks
shawaditya is offline   Reply With Quote
Old   October 30, 2022, 16:07
Smile
mahdi abdollahzadeh
mm.abdollahzadeh is on a distinguished road
If you had any success with the plasma torch model can you share a case here?
I have developed a code for that but I am facing problem with converging temperature
mm.abdollahzadeh is offline   Reply With Quote
Old   July 11, 2023, 04:52
niming
sixgod is on a distinguished road
Thanks
Excuse me, have you solved it now? I have the same problem.
sixgod is offline   Reply With Quote
Suppress twoPhaseEulerFoam energy AlmostSurelyRob OpenFOAM Running, Solving & CFD 33 September 25, 2018 18:45
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
