Dividing Objects Symmetry
Like Tree2Likes
  • 1 Post By Tait10
  • 1 Post By vinerm
Old   March 30, 2020, 01:07
Default Dividing Objects Symmetry
Babal Cobelt
babalcobelt is on a distinguished road
Hey,
I want to simulate the flow of air with the heat transfer process on the square pipe with a very small size (side width of 3 mm). Because of its small size, I can only make it with a small amount of mesh so the results are not accurate.
To get more accurate results and shorten the simulation time, I divided the square pipe into 4 parts of symmetry and performed a simulation on one of these parts.
I have tried it but the results are not like a part of a 1/4 square pipe, but like a part of a complete pipe but with the size of 1/4 its original size.
How do you make the 1/4 part of the square pipe really represent the state of the real 1/4 part of the whole square pipe?
babalcobelt is offline   Reply With Quote
Old   March 30, 2020, 02:07
ZT
Tait10 is on a distinguished road
You will need to put symmetries on the two sides that would be on the inside of the pipe. For example, if you wanted to model the top-right 1/4 of the pipe, the top and right bc must be a wall, however the bottom and left bc must be a symmetry.
babalcobelt likes this.
Tait10 is offline   Reply With Quote
Old   March 30, 2020, 03:37
Babal Cobelt
Thank you for your response
In this case I have tried it with the bottom-left 1/4 of the pipe, the bottom and left b.c. are the walls, and the top and right b.c. are symmetry with adiabatic condition.
But the result remains like a whole square pipe with 1/4 size of the original, while the process in it does not describe its condition which is 1/4 part.
For example: the air flow in 1/4 of the pipe is centered at the blue dot like the following picture, which should be in the top right corner like the original.
Old   March 30, 2020, 04:51
Default Symmetry
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
If you use symmetry, then you won't get an option to apply adiabatic condition or any condition for that matter. Symmetry automatically implies adiabatic condition. So, in case after applying symmetry you still get an option for thermal condition where you can apply adiabatic, then that is not symmetry condition. Other option is to use Wall with Specified Shear of 0 and adiabatic. As long as there is no field other than flow, turbulence, and thermal, this would behave like symmetry.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 30, 2020, 05:23
Babal Cobelt
Got it
Thank you
heat-transfer, quarter-section, square-channel, square-pipe
rhoSimpleFoam - Newbie Issues AndyR OpenFOAM Running, Solving & CFD 6 March 10, 2020 10:28
High nut values in random place and time krzychu111 OpenFOAM Running, Solving & CFD 0 January 9, 2019 09:42
Issues with symmetry patches perpendicular to outlets sturgeon OpenFOAM Running, Solving & CFD 2 October 9, 2017 10:46
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 04:13
