March 6, 2020, 07:31 |
Error in UDF for slip boundary
Amit Varakhedkar
I have written a UDF for providing slip conditions to the airfoil wall using the Navier slip equation. After compiling the code, when I initialize the solution, I get this error: received a fatal signal (Segmentation fault).
I am simulating in series and the simulation is running perfectly for no-slip condition (without UDF). Thanks in advance. The UDF is as follows: #include "udf.h" #define del 0.0004 // wall slip layer thickness [m] DEFINE_PROFILE(slip_velocity_x,t,i) { cell_t c; real x[ND_ND], gamma, c_t, c_x, u, v; face_t f; begin_f_loop(f,t) { F_CENTROID(x,f,t); u = C_U(f,t); v = C_V(f,t); gamma = C_STRAIN_RATE_MAG(f,t); // tangential velocity component c_t = gamma*del; c_x = c_t*u/sqrt(u*u+v*v); // taking x component F_PROFILE(f,t,i) = c_x; } end_f_loop(f,t) } DEFINE_PROFILE(slip_velocity_y,t,i) { cell_t c; real x[ND_ND], gamma, c_t, c_y, u, v; face_t f; begin_f_loop(f,t) { F_CENTROID(x,f,t); u = C_U(f,t); v = C_V(f,t); gamma = C_STRAIN_RATE_MAG(f,t); c_t = gamma*del; c_y = c_t*v/sqrt(u*u+v*v); F_PROFILE(f,t,i) = c_y; } end_f_loop(f,t) } |
March 6, 2020, 08:26 |
Slip Velocity UDF
There are a few issues with the code. Any macro starting with C_ is meant for cell center. And it requires cell index and cell thread, i.e., the arguments of C_ macros have to be of type cell_t and Thread *t where t belongs to a cell zone and not a boundary zone. You have to define a thread variable outside the loop, i.e.,
Thread *tc; tc = THREAD_T0(t); and incorporate following changes within the loop c = F_C0(f, t); C_STRAIN_RATE_MAG(c, tc); Furthermore, you don't need the command F_CENTROID as well as its corresponding variable x because these are not required by the equation. Last comment is about its applicability. It is not recommended to apply the velocity for a slip or partial slip condition. Better approach is to determine shear stress due to this slip and then apply that.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
segmentaion fault, slip b.c., udf |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 06:53 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 06:57 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
