error writing during calculation
Like Tree2Likes
  • 1 Post By LuckyTran
  • 1 Post By vinerm
Old   February 20, 2020, 11:56
Default error writing during calculation
KLA
KLA is on a distinguished road
Hi all,
I have a problem when launching simulation on ansys fluent. I use transiant, K-omega SST. When I launch simulation I get this error:
Error: Error writing "| gzip -2cf > SYS-1-00000.dat.gz".
Error Object: #f
any suggestions as to why this is happening ? Thanks in advance !
KLA is offline   Reply With Quote
Old   February 20, 2020, 12:27
Lucky
Could be unable to access dir or no write permissions
Could be the gnuzip bug on Windows 10.
Try not using .gz
KLA likes this.
Old   February 20, 2020, 12:33
Default Or RAM
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Fluent gives this error if there is not enough RAM to compress the file. Try writing as unzipped, i.e., without .gz. If it still doesn't write, then there is something wrong with the setup or initialization.
KLA likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   February 20, 2020, 16:12
Smile
KLA
thank you vinerm and lucktran for your answer.
May I please ask for further information about how to do so ?
Thank you again
Old   February 20, 2020, 16:22
Default Extension
vinerm's Avatar
Vinerm
Fluent writes files as per the extension provided by the user. If you provide extension as .cas.gz or .dat.gz then it tries to zip the file. If the extension is given as .cas or .dat then the file is written in unzipped form.
Regards,
Vinerm
fluent
Dynamic mesh adaption in parallel calculation xh110120 FLUENT 1 March 12, 2016 09:05
Determining the calculation sequence of the regions in multe regions calculation peterhess OpenFOAM Running, Solving & CFD 4 March 9, 2016 04:07
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 09:46
Warning 097- AB Siemens 6 November 15, 2004 05:41
Heat Flux Calculation under REPORTS Alberto Schroth FLUENT 0 May 16, 2000 09:19
