Not able to change the 'type' in boundary condition
Like Tree1Likes
  • 1 Post By vinerm
Old   February 18, 2020, 05:18
Smile Not able to change the 'type' in boundary condition
Jigar
jigarfaria is on a distinguished road
I'm following a tutorial on this https://www.afs.enea.it/project/nept...tg/node261.htm webpage. In a particular workbench project, I'm able to change the type of 'contact-regio-trg' whereas in another project in the same workbench file I'm not able to change the type of 'contact-regio-trg' to a wall. I've attached the cut-section of the geometry that I've been using. The inner part has been hidden from the geometry.
It would be great if any insight would be provided on this issue.
jigarfaria is offline   Reply With Quote
Old   February 18, 2020, 08:06
Default Mesh Interface
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
To change the type, first you need to delete the mesh interfaces that use these boundaries.
jigarfaria likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   February 19, 2020, 01:12
Jigar
Thanks a lot. It solved the problem.
ansys 18.1, boundary condition, fluent, geometry, wall
activeBaffleVelocity boundary condition ? om3ro OpenFOAM Programming & Development 10 November 17, 2020 00:26
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
