How to set initial pressure
Like Tree1Likes
  • 1 Post By vinerm
Old   February 14, 2020, 09:24
Default How to set initial pressure
KevNo
KevNo is on a distinguished road
Hello! I'm a newby in Fluent and have a question:
I want to model a countercurrent-flow tube heat exchanger.
The flow through the tubes has an initial pressure of 250000 Pascal (temperature 40 degrees) - velocity inlet.
The flow around the tubes has an initial pressure of 450000 Pascal (temperature 15 degrees) - velocity inlet.
I have two corresponding pressure outlets. I want to simulate the flow and the temperature gradient (energy equation and viscous flow are activated). I'm using a pressure-based solver in the steady case.
So, where can I set the initial pressure? In the inlets are only supersonic pressure and in the outlets backflow pressure given...
Thank you!
KevNo is offline   Reply With Quote
Old   February 14, 2020, 12:02
Lucky
In the initialization pane. It looks like so.
Old   February 14, 2020, 14:29
Default Initial Pressure
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
There are multiple ways to initialize at different pressure values, however, the initialization would have no effect if the system is incompressible. You can initialize with same pressure. If the system, however, is compressible, you have to initialize all domains at same pressure, say lower of the two, using the initialization dialogue box, as shown by Lucky and then use the patch within the same dialogue box to initialize the other domain at higher pressure.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   February 17, 2020, 06:59
KevNo
Thank you both!
I have incompressible flow with water on both sides. So, I don't need to initializie with the pressure? But where can I setup this information?
Old   February 17, 2020, 08:09
Default Incompressible
vinerm's Avatar
Vinerm
For an incompressible system, pressure has no relevance. Only its drop is important. Therefore, you do not need to set different pressure values. However, if you have some model, e.g., evaporation-condensation or cavitation, where value of pressure is important, then you have to set pressure accordingly. You can use patch option for the same.
Haitham Osman CFD likes this.
Regards,
Vinerm
Old   February 17, 2020, 13:19
Lucky
You still need to initialize the pressure field. The point is that the value of pressure has a slightly different meaning for an incompressible fluid. Regardless, Fluent is a compressible N-S solver even when the Fluid is incompressible.
fluent, pressure
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 10:10
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 14:47
decompose dependent solution arionfard OpenFOAM 3 December 10, 2018 10:36
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
