How to use Fluent Scheme to change the boundary condition defined by UDF
Like Tree2Likes
  • 1 Post By vinerm
  • 1 Post By heke402
Old   February 4, 2020, 14:24
Default How to use Fluent Scheme to change the boundary condition defined by UDF
Ge
heke402 is on a distinguished road
Hi all,
I know there are some discussion on how to use Fluent Scheme to change boundary condition and I followed their instructions and made it work. Now the only question I have is if I define the boundary condition using UDF (DEFINE_PROFILE()) then what the format of the scheme should be? The scheme file I wrote is as the following
(define (changeboundary)
(cond
((and (>= (rpgetvar 'flow-time) 0.001) (<= (rpgetvar 'flow-time) 0.002))
(ti-menu-load-string "define/boundary-conditions/zone-type 10 wall"))
(else
(ti-menu-load-string "define/boundary-conditions/zone-type 10 mass-flow-inlet")
(ti-menu-load-string "define/boundary-conditions mass-flow-inlet 10 mass_flow y"))
where "mass_flow" is my UDF name. I tried several times by executing the scheme file at each time step but it looks like Fluent did not recognize the UDF I used to define the boundary.
heke402 is offline   Reply With Quote
Old   February 4, 2020, 17:36
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
(ti-menu-load-string "define/boundary-conditions mass-flow-inlet 10 \"mass_flow\" y"))
it is possible that in your code between 10 and mass_flow should be other setting, check through TUI
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   February 5, 2020, 04:39
Default Include full TUI command
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
TUI commands are sequential, i.e., you cannot miss anything in between. Full TUI commands changes from case to case, depending upon which models are enabled. A RANS based model with flow, without any other model enabled would require
def bc mfi 10 y y y y "functionname::libraryname" n 0 n y n n y 3.7 5
This command assumes that the library is already loaded. If it is not, then you have to load the library using
def user comp load "libraryName"
arashjkh likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   February 5, 2020, 10:22
Ge
Hi AlexanderZ,
Thanks for the help! I checked through TUI and my issue has been solved.
Old   February 5, 2020, 10:25
Ge
Hi vinerm,
Thank you so much for the help! I have solved this issue by using the correct TUI command as you mentioned.
Old   February 5, 2020, 12:30
Ge
Dear AlexanderZ,
I have one more question. By looking up the TUI and answering all the questions, I found for my case the correct TUI commands should be
ti-menu-load-string "define/boundary-conditions mass-flow-inlet 10 yes yes yes yes "udf" "mass_flow::libudf" no 0 no yes"
However, when I typed "udf" in the console window to answer the question, there is no problem about it and Fluent can recognize what I typed. But when I wrote the TUI command into a scm file and execute the file at each time step during simulation, I always got an error as "Error: eval: unbound variable; Error Object :udf". I use ANSYS 16.0 and I am confused why Fluent can recognize "udf" in console window but can not do it in scm file. Could you please help me solve this issue, thank you in advance for your help!
Old   February 5, 2020, 12:35
Ge
Dear vinerm,
Old   February 6, 2020, 00:42
Alexander
use \" not "
best regards
Old   February 6, 2020, 04:04
Default Escape character
vinerm's Avatar
Vinerm
It depends whether you are using TUI within a ti-menu-load-string command or not. Since there is already double-quote opening the command, you have to escape the second one. So, command has to be
(ti-menu... "udf" "mass_flow::libudf" ...)
i.e., just use escape character before double quotes.
Regards,
Vinerm
Old   February 6, 2020, 04:12
Default HTML issue
vinerm's Avatar
Vinerm
Apparently, cfd-online is escaping is not displaying \ character before double-quotes. Use \ before every double quote and it will work.
Regards,
Vinerm
Old   February 6, 2020, 10:50
Ge
Hi vinerm and AlexanderZ,
Thank you so much for your help! After adding escape character before double quotes, the problem has been solved.
Fluent change boundary condition type using Scheme syntax in journal file lytemar Fluent UDF and Scheme Programming 4 April 28, 2022 03:13
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 01:55
