Actuator disk model for populsor on aircraft
Like Tree1Likes
  • 1 Post By vinerm
Old   February 1, 2020, 23:34
Default Actuator disk model for populsor on aircraft
Jaxx is on a distinguished road
I am trying to investigate the effects a certain propulsor has on re-energizing boundary layer flow over an aircraft body, using ANSYS Fluent. I have been told to model the propulsor using the actuator disk model (momentum source) and porous jump (momentum sink). I am new to ANSYS and when I try researching actuator disk model, I can't find any tutorials/info that describes it properly and how to use it in ANSYS. I also don't understand how using the actuator disk model and porous jump will help me investigate the effects the propulsor has on re-energising the flow.
Can someone help me understand the actuator disk model and porous jump (their purposes and how to implement them in a 2D ANSYS simulation). Do I have to make the propulsor on solidworks, import to ANSYS and then turn it into an actuator disk?
Any help will be appreciated as I am really struggling with this.
Thank you
Jaxx is offline   Reply With Quote
Old   February 2, 2020, 05:51
Default Vbm
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
In Fluent, it is called Virtual Blade Model. Most likely it is a beta feature. Earlier it was available only as a compiled UDF.
mhal6932 likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
actuator disk, porous jump
viewFactor radiation model stuck shach934 OpenFOAM 1 May 25, 2021 12:01
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
NEW turbulence TRANSITIONAL model giammy92 OpenFOAM 3 June 30, 2016 10:47
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
