January 30, 2020, 03:50 |
Pigging Analysis
Ali
I am new to Ansys Fluent and given the assignment to analyze Pig motion in a pipeline. The pipeline is around 2000m long and Ansys and Solidworks cannot make that length of the pipeline, so how would you suggest to go for the boundary conditions to analyze this issue I am adding a document too from you can understand what I am asking. Thanks & Regards Image 1.jpg Image 2.jpg |
January 30, 2020, 05:50 |
Too involved
The scenario is rather involved and would require Fluid-Structure Interaction. However, with assumptions that the cups are rigid and the pig always moves in a straight line along the pipeline, you can use rigid body solver along with moving mesh in Fluent to simulate it. Boundary condition can be velocity inlet and pressure outlet. Since fluid is liquid, pressure at outlet can be 0 Pa (gauge).
Another option is to use CFX with its IB method. It would not require any moving or deforming mesh. But this is not scalable, i.e., you will not be able to extend it to the option of deforming cups.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
January 30, 2020, 05:58 |
Curious
Ali
Hi Vinerm,
I hope you have looked upon the images that I have attached to my query. Actually the fluid is natural gas not liquid. The inlet and outlet conditions are also mentioned. The thing I am not understanding is how can I add boundary conditions to the 2000m long lines end if I cannot model it in the software? Thanks |
January 30, 2020, 08:28 |
No limit
There are no such limitations in the system. We have modeled snow avalanches on mountains using Fluent over the areas of 20 km x 20 km.
ansys, fluent, pigging, solidworks |
Urgent - Perform an DISCRETE adjoint analysis in parallel_computation | JPBLourenco | SU2 | 1 | April 23, 2018 10:38 |
Explicit dynamics results for initial condition to another explicit dynamics analysis | KOI | Structural Mechanics | 0 | March 2, 2018 04:16 |
How to implement a sensitivity analysis for certain items | Mason liu | CFX | 10 | August 17, 2017 08:46 |
FSI-system coupling: "...same analysis type"? | rjw | CFX | 0 | March 26, 2017 07:25 |
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload | ingjuanm90 | ANSYS | 0 | July 26, 2016 14:04 |
