Reynold's Number 30000
Like Tree4Likes
  • 1 Post By Vaelyn
  • 1 Post By arnie333
  • 1 Post By shereez234
  • 1 Post By vinerm
Old   January 21, 2020, 13:30
Default Reynold's Number 30000
Saugat Shrestha
saugatshr4 is on a distinguished road
I am relatively new to Ansys Fluent. For Reynold's number of 30000, I'm getting a drag of 0.5 (The correct drag should be around 1.2) with a time step of 0.002 seconds. I ran the simulations for 25 seconds, and it still is the same?? I'm running the K-epsilon model for airflow around a cylinder. What should I do to get the correct result??
-Decrease the time step
-Use finer Mesh
-Run the simulation for longer to obtain the correct result
saugatshr4 is offline   Reply With Quote
Old   January 21, 2020, 14:00
Vaelyn is on a distinguished road
You could refine the mesh by the cylinder-gas interface. The time-step and seems fine if it is converging well.
saugatshr4 likes this.
Vaelyn is offline   Reply With Quote
Old   January 21, 2020, 15:32
Arnie
arnie333 is on a distinguished road
You need to describe your analysis in more detail.
Is it an external or internal flow analysis ?
What are you analyzing and where did you get the correct Cd of 1.2 ?
Did you input the correct Reference Values ?
If the flow is around an object then Re of 30 000 is turbulent flow and k-epsilon model is acceptable if Y+ lies between 30 and 300. Remember that you are not directly resolving the shear stress, but rather using a model that applies a near-wall treatment.
To accurately resolve the wall shear stress in the boundary layer, I would rather use k-omega SST with a Y+ between 0.1 and 2
arnie333 is offline   Reply With Quote
Old   January 22, 2020, 05:51
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
-Use finer Mesh
Like others said. So many questions comes to mind?
Geometry is 2D?
What reference area are you using?
Is your Y+ <1?
Is your viscosity and far field velocity/pressure correctly set?
Do you have a plot of the convergence?
shereez234 is offline   Reply With Quote
Old   February 3, 2020, 01:09
Saugat Shrestha
It is an internal wind tunnel analysis. The walls and the cylinder is initialized as the no-slip condition. It is a 2D condition. I am using the standard default reference values. The reference value is 1, and even when I calculate my Cd it is incorrect. I am getting somewhere around 1.2 but I am getting 0.5.
So, from the literature from the flow around a cylinder the Cd is 1.2. It attainable for low Reynolds number till 1000 but I seem to have a problem for higher Reynolds number.
I am trying the k-w model, as it gives better results for the near-wall region. I have the same problem with incorrect drag.
I m trying to have the +y value less than 1 but, it seems that the mesh size has to be substantially small to attain >+y condition. How do we get a +y<1? I have attached the images of the associated files. https://drive.google.com/drive/u/0/f...moHiW5vV31k_tb
Old   February 3, 2020, 03:57
Default C_d is not absolute
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
It is the drag force that is based on the flow-field and not its coefficient. C_d is the ratio of the drag force to some normalizing force. And, hence, if you use a different force to normalize, you get a different value and all those values are correct as long as you also report the normalizing force used. To avoid this, standard normalization values are used. Therefore, you have to modify your reference values; Fluent uses these reference values to calculate normalizing component. You have to modify length scale, velocity scale, and density. Use free-stream values for the velocity and density, and diameter of the cylinder as length scale. y^+ is alright; lower could be better but it is not bad.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 19:32
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 09:14
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
