WARNING 'Vertex' values for Variable 'xxx' do not exist |
Gianmario Ledda
Rep Power: 7 ![]() |
Dear all,
I'm working with Fluent and I need to create the expression to use the custom variable (ex.xxx). But when I define my variable the following an error message appear: "WARNING 'Vertex' values for Variable 'xxx' do not exist on Geometry /DATA READER/CASE:Case case_file_name/BOUNDARY:desired-surface. ". this error is due to the following expression: Temperature^4-298.15^4. How I can fix it? Thanks ![]() |
MLutfiFauzi
Try to write Temperature - 10 or anyting else and the same error will come. I encouter same problem with you.
It just will fine if Temperature*2 or anyting except + and -. |
MLutfiFauzi
Did you have solve your problem? I'm still confuse
Anonymous
Rep Power: 0 ![]() |
Kennie
Rep Power: 4 ![]() |
Hello there,
Might be a little late but in case someone needs this : I had the same issue with a user-defined variable on CFD-Post and the reason I had that warning is because in a specific area of my geometry, the variable went to an infinite value. The denominator of the variable was 1-Z (Z being another variable, the mixture fraction, which is between 0 and 1) and in order to not reach infinity, I simply wrote 1.00001-Z at the denominator instead in my user defined-variable. That solved the problem very well without making a significant difference to my results. Cheers! |
fluent, post procesing, variable definition |
setfields for alpha | belkadi | OpenFOAM Programming & Development | 7 | November 25, 2014 11:53 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
