Unable to get Yplus less than 1
Like Tree1Likes
  • 1 Post By LuckyTran
Old   December 23, 2019, 02:06
Default Unable to get Yplus less than 1
Zohaib Altaf
zohaibaltaf.6 is on a distinguished road
Hello!
I am working on a developing flow through diffusing duct of aircraft.
Boundary conditions: pressure inlet & mass flow outlet
Model: k-omega SST
I am stuck in the results of yplus i.e.
Area weighted average of yplus at wall = ~70
As, model demands y+<1. I have checked different mesh sizes (b/w 1-20 million cells) but unable to get y+<1.
1st cell height = ~ 1x10^-6
Layers=~ 42
Height ratio = 1.2
Please help me in this. Thanks
zohaibaltaf.6 is offline   Reply With Quote
Old   December 25, 2019, 08:25
João de Sousa Bomfim Neto
Joao Bomfim is on a distinguished road
Hi. How you obtained y+ value?
Joao Bomfim is offline   Reply With Quote
Old   January 1, 2020, 03:44
Zohaib Altaf
Using area weighted average over the wall
Old   January 2, 2020, 07:03
Exclamation
Roh
Roh is on a distinguished road
Why "area weighted average"?
Fluent has plot tools to plot the Y+ over a wall.
Roh is offline   Reply With Quote
Old   January 16, 2020, 13:59
Zohaib Altaf
thank you, i have also used plot tool and it shows different values at different patches
Old   January 16, 2020, 14:01
Zohaib Altaf
And somwhere it is close to 1 but other locations have higher y+ around 70
Old   January 17, 2020, 02:40
Lucky
It's clear what you have to do to get a smaller wall y+. Make smaller cells there.
You probably will never get the wall y+ <1 globally. You can tinker with it for a month and you might end up with one location where it is 2.
zohaibaltaf.6 likes this.
developing flow, diffusers, duct flow, k-w sst, yplus
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
yPlus twoPhaseEulerFoam Andrea_85 OpenFOAM Post-Processing 4 January 11, 2021 06:01
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 07:08
How to make a code parallel? Bruno Machado Fluent UDF and Scheme Programming 15 May 27, 2016 10:18
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 16:45
