How to determine NTGK parameters in Ansys Fluent? |
December 17, 2019, 13:04 |
Rep Power: 6 |
For my thesis I'm designing a batterypack for an application. Currently I'm trying to determine the U and Y coefficients for the NTGK battery model. Because I'm not able to do any experiments yet I used a graph delivered by the battery supplier (Voltage in functon of time in minutes). You can see the graph below. I extracted the values from the graph and wrote them in three .txt files (1C;2C and 3C). Completely below the text files are shown. With the parameter estimation tool I've readed the .txt files into Ansys. The tool calculated the Y and U parameters as shown below. I also added the model options (50Ah 3,2V pouch cell). As you can see the parameter bo isn't correct because it's shown in a red box. This parameter should be a positive number. The experimental and fitted results are shown below. As you can see these results doesn't match the first graph at all and I can't figure it out what I'm doing wrong. Text file 1C rate (time in seconds | voltage in V): Crate 1.0 0001e+00 3.400e+00 0068e+00 3.252e+00 0194e+00 3.252e+00 0332e+00 3.249e+00 0466e+00 3.247e+00 0597e+00 3.239e+00 0862e+00 3.231e+00 0994e+00 3.225e+00 1260e+00 3.217e+00 1392e+00 3.213e+00 1657e+00 3.206e+00 1922e+00 3.198e+00 2320e+00 3.188e+00 2585e+00 3.172e+00 3248e+00 3.119e+00 3703e+00 2.889e+00 3832e+00 2.576e+00 3878e+00 2.368e+00 3949e+00 2.146e+00 3989e+00 2.003e+00 Text file 2C rate: Crate 2.0 0001e+00 3.400e+00 0060e+00 3.187e+00 0200e+00 3.178e+00 0333e+00 3.172e+00 0465e+00 3.165e+00 0598e+00 3.156e+00 0730e+00 3.151e+00 0863e+00 3.141e+00 0995e+00 3.131e+00 1261e+00 3.108e+00 1515e+00 3.058e+00 1656e+00 2.976e+00 1744e+00 2.838e+00 1776e+00 2.750e+00 1802e+00 2.599e+00 1825e+00 2.504e+00 1850e+00 2.383e+00 1892e+00 2.195e+00 1901e+00 2.101e+00 1913e+00 2.012e+00 Text file 3C rate: Crate 3.0 0001e+00 3.400e+00 0001e+00 3.134e+00 0134e+00 3.118e+00 0267e+00 3.109e+00 0400e+00 3.098e+00 0532e+00 3.090e+00 0665e+00 3.073e+00 0798e+00 3.055e+00 0919e+00 3.027e+00 0997e+00 2.990e+00 1041e+00 2.955e+00 1075e+00 2.912e+00 1087e+00 2.869e+00 1113e+00 2.823e+00 1155e+00 2.623e+00 1201e+00 2.472e+00 1198e+00 2.388e+00 1226e+00 2.219e+00 1226e+00 2.180e+00 1250e+00 2.009e+00 |
December 19, 2019, 06:59 |
Rep Power: 6 |
December 24, 2019, 09:59 |
Rep Power: 6 |
Bump
December 25, 2019, 18:33 |
Alexander
Rep Power: 34 |
you can fit parameters yourself, google paper regarding NTGK method
for example: K. H. Kwon et al. “A Two-dimensional Modeling of a Lithium-polymer battery”. Journal of Power Sources. 163. 151-157. 2006.
best regards ****************************** press LIKE if this message was helpful |
December 19, 2022, 20:05 |
Thiago
Hi, did you end up getting the right parameters of U and Y coefficients? If so, can you please explain me how you did it? Thanks in advance
March 3, 2023, 18:08 |
hi
ahmet kaya
Rep Power: 6 |
did you solve?
Can you help me with a problem in ansys static structural solver? | sourabh.porwal | Structural Mechanics | 0 | March 27, 2016 18:07 |
How to determine intra-articular pressure in ANSYS Fluent | sophietay93 | FLUENT | 0 | January 26, 2016 11:57 |
ANSYS and ANSYS Fluent | Field85 | ANSYS | 3 | May 17, 2015 17:21 |
export data from fluent to ansys | galapago | FLUENT | 0 | August 4, 2010 15:04 |
Fluent & Ansys FSI architecture help | DillonS | FLUENT | 1 | April 7, 2010 17:00 |
