Hydraulic Diameter for Axisymmetric Problem
Like Tree1Likes
  • 1 Post By LuckyTran
Old   December 16, 2019, 11:29
Question Hydraulic Diameter for Axisymmetric Problem
samm
Jegan is on a distinguished road
Hello Everyone,
How can i calculate the turbulence inlet value (hydraulic diameter) for axisymmetric case.
Normally diameter is considered as hydraulic diameter,here i can put one injector value as it is i.e, the diameter of that inlet. And how can i calculate hydraulic diameter for another inlet(which is along axis).
Thanks.
Jegan is offline   Reply With Quote
Old   December 16, 2019, 12:19
Lucky
Wait what? It doesn't matter if you simulate it using an axissymmetric approach. What's the whole injector thingy look like? Isn't it still a circle with a clearly defined diameter? Use that.
Jegan likes this.
combustion, inlets, nonpremixed, turbulence
diameter equivalent and hydraulic diameter medaouarwalid Main CFD Forum 6 June 22, 2017 03:33
Hydraulic diameter for multiple ducts jalay FLUENT 2 August 23, 2013 05:17
Hydraulic Diameter vigii FLUENT 2 January 14, 2012 11:29
equivalent diameter vs hydraulic diameter swamysrikanth Main CFD Forum 1 April 5, 2010 10:01
Hydraulic diameter vs radius Christian Main CFD Forum 8 August 5, 2009 19:10
