How To write a Correct UDF (FLUENT) for Specific heat as Function of Temperature for
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   December 4, 2019, 21:37
Default How To write a Correct UDF (FLUENT) for Specific heat as Function of Temperature for
ATUL S B
atulsbhat is on a distinguished road
This UDF didnt Get Any Error message but its not running, Can someone correct the UDF BELOW? {Suggest Changes Required}
Should I add anything Related To Enthalpy or Some UDM MACRO like C_UDMI(c,t,0) = cp
DEFINE_SPECIFIC_HEAT(cell_SpecificHeat, T, Tref, h, yi)
real T = C_T(c, t);
real cp;
if (500< T <550)
cp = (0.63464529*pow(T,2))-(356.13993666*T)+(61767.53243895);
else if (550< T <600.10)
cp = (0.23484528*pow(T,2))-(250.13953470*T)+(71466.09249852);
else if (600.10< T < 625.15)
cp = (1.58260392*pow(T,2))-(1873.17493506*T)+(560143.47661247);
else if (625.15< T <640)
cp = (16.13751699*pow(T,2))-(20137.03882161*T)+(6289718.12316515);
else
cp = 13000;
*h = cp*(T-Tref);
return cp;
Regards
atulsbhat is offline   Reply With Quote
Old   December 6, 2019, 07:10
sufjanst is on a distinguished road
Did you hook the UDF and set it up as your material properties?
sufjanst is offline   Reply With Quote
Old   December 6, 2019, 16:26
Default How To Set Tref And What Should be my Tref for The Above UDF?
ATUL S B
Yes I Did That..
I am Not Sure Where to Set Tref For Cp in the Material Section
Old   December 9, 2019, 01:07
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
COMPILE your code and READ error log file,
you've defined T twice
remove real T = C_T(c, t);
atulsbhat likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 10, 2019, 11:57
ATUL S B
I am Not Sure Where to Set Tref For Cp in the Materials Panel
Where Can I set Tref for UDF?
Should I Define it in My UDF ?
Like real Tref=600;
or its Not Possible to Alter it (by default its 298K) ?
In the Manual There is No Mention of how to add it..
{Only for multiphase there is an option because of latent heat}
What Is Tref, will it effect my Cp or its only for sensible enthalpy calculation??
ansys fluent 18.0, ansys fluent 19.0, cfd - post, fluent - udf, udf and programming
UDF for specific heat as function of pressure ghobold Fluent UDF and Scheme Programming 20 August 22, 2019 09:19
Linking initial data and source terms from UDF to Fluent in simulating heat pipe say2017 Fluent UDF and Scheme Programming 0 October 20, 2017 13:35
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
