Changing fluent default settings
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   November 21, 2019, 00:11
Smile Changing fluent default settings
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hi All,
For most of my simulations, I will be changing a lot of fluent default parameters like pressure unit from pascal to psi, solution backup interval from 0 to 500, iterations to store to 5000, etc. How can I change these settings permanently so that every time I launch the fluent it will load with the modified setting.
I heard that there is an option to edit a fluent.bat file to change the default settings but I am unable to find the details about that.
Regards,
Sunil
sunilpatil is offline   Reply With Quote
Old   November 21, 2019, 00:58
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
make a journal file with all your settings
LuckyTran likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 21, 2019, 09:42
Lucky
Just in case you had any doubts. Make a journal file
Old   November 22, 2019, 04:58
sunilpatil's Avatar
sunil
Hi Tran,
thank you for your reply, if I make a journal file then how can run it automatically when fluent starts.
Regards,
Sunil
Regards,
Sunil
Old   November 22, 2019, 11:33
Lucky
You don't need to run it automatically, although you could.
When you launch Fluent, you can set it to run your journal. Or you can manually run it it (by just typing file/read-journal), or it's just 3 button clicks in the GUI.
It's just the standard practice that everyone (that wants this level of control) has a journal file and runs it at some point.
Old   November 25, 2019, 01:16
Alexander
journal file could be run automatically, however, I don't remember how to do this
as far as I remember, some folder should be created in working directory with special name
that folder should contain your journal file with special filename extension
best regards
changing default
Some settings were missing if exported from Hypermesh to Fluent QQ1034914840 FLUENT 0 June 19, 2016 16:04
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting arunraj FLUENT 0 June 2, 2016 23:58
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Fluent default surface boundary condition lalupp FLUENT 2 February 27, 2012 04:30
Changing default values dcwnj CFX 1 February 6, 2008 16:46
