Help in Beam Width and Direction using DO radiation model |
Subham
Rep Power: 7 ![]() |
Dear All,
I have to define a cylindrical radiation beam in the DO radiation model in Ansys Fluent. Can someone guide me on how to choose a relevant beam width and height in order to set the profile? Also, is it possible to write a UDF that would allow only certain faces of a wall to behave as semitransparent and the remaining as opaque? Thanks |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Beam height??
Beam width is a solid angle in steradians. If your beam is cylindrical, the beam width is technically 0 (but you should input a very small number, which is the default anyway). So you actually don't have to provide anything here. You do, need to give the beam direction, if applicable. If it's normal to the boundary then it's trivial. Don't just straight to the most complicated UDF for all your needs. You can just split the boundary. Or even profile a heat flux profile and set the heat flux to 0 for the the opaque portions. |
Subham
Thanks a lot for helping me out. I was able to solve the issue
Valentine
Rep Power: 0 ![]() |
Please I'm working on specie transport and trying to consider radiaition effect of the fire using discrete ordinate radiation model. Please what are the best BC to apply? also whats beam direction and what is best to set it as? thanks. |
ansys fluent 19.2, beam width, do radiation model |
How to change LED beam angle properties in fluent radiation BC? | Loki | FLUENT | 0 | April 21, 2019 03:36 |
how to set the "beam width" and "beam direction" in the DO radiation model | jeniuswx | FLUENT | 1 | March 6, 2017 02:04 |
Radiation Beam - DOM | fshak92 | STAR-CCM+ | 0 | December 28, 2012 07:35 |
How to choose or find Permeability for a Porous screen model using darcy's law.... | arunraj | CFX | 4 | September 27, 2011 00:20 |
DO radiation model | hong | FLUENT | 0 | November 20, 2007 06:59 |
