Fluent .dat problems on HPC
Like Tree1Likes
  • 1 Post By LuckyTran
Old   November 3, 2019, 13:19
Default Fluent .dat problems on HPC
ZT
Tait10 is on a distinguished road
Currently moving from my own computer to HPC. Learning a lot about bash scripts and have run into a couple of barriers.
When writing a .dat file, it appears to only give me the last timestep saved in that .dat file. Do I need to write a new .dat file for every timestep along the way in order for it to save every timestep? I am using TecPlot as my post-processor if that helps. If this is the case, is there another command for that that doesn't end with me using 6000 lines of code in one .jou file?
Do I also need to write a .cas file along with the .dat file? No moving mesh so I wouldnt have thought it needed it on every ts, just at the end. .jou file posted below for you to have a look, cheers in advance.
; Read case file
rc FFF.1-Setup-Output.cas.gz
; Initialize the solution
/solve/initialize/hyb-initialization
; the time-step size as 0.01 (seconds)
/solve/set/time-step 0.01
;No of it
;Max it per time step
/solve/dual-time-iterate
1000
20
; Write data file (compressed, iteration number included in file name)
wd initial_testing_output_ts10.gz
;No of it
1000
20
wd initial_testing_output_ts20.gz
; Exit FLUENT
exit
yes
Tait10 is offline   Reply With Quote
Old   November 4, 2019, 11:04
Lucky
The .dat file only contains the variables at the time-step when it is saved. If you want data from multiple time-steps, then yes you need to save a bunch of .dat files.
You do not need to save a .cas file every time since the mesh does not change.
Easiest way is to setup automatic saving of .dat every x time-steps. In the GUI you'd go to File=>Write=>Autosave in the ribbon. But you can also find it in Calculation Activities=> Autosave.
If you want to use TUI commands, they are:
/file/auto-save/root-name
 /file/auto-save/append-file-name
/file/auto-save/case-frequency
/file/auto-save/data-frequency
 /file/auto-save/retain-most-recent-files
Brief tutorial:
/file/auto-save/root-name "path/myCase"
Usually you can skip this command entirely if you plan to save in the working directory
Then you will need:
/file/auto-save/append-file-name-with time-step 6
or
/file/auto-save/append-file-name-with flow-time 6
Most people have a preference for either the physical simulation time or the time-step counter in their filenames. 6 is number of decimals for the flow-time/time-step. Use the default 6 or adjust to your needs.
/file/auto-save/case-frequency [arg]
take one of three arguments
each-time
if-case-is-modified
if-mesh-is-modified
Pretty self-explanatory. You'll want one of the later two, doesn't really matter which one.
/file/auto-save/data-frequency 1
1 will save a .dat file every time-step. Usually a bigger number (i.e. 10, 100, etc.), but set this for your purpose.
/file/auto-save/retain-most-recent-files no
set to no so that it doesn't delete the .dat files automatically
Actual example:
/file/auto-save/append-file-name time-step 6
/file/auto-save/case-frequency if-mesh-is-modified
Put these lines somewhere before your /solve/dual-time-iterate
mcuneytk likes this.
Old   November 4, 2019, 16:34
ZT
Brief tutorial:
Then you will need:
or
each-time
if-case-is-modified
if-mesh-is-modified
Actual example:
This is fantasic, thanks so much. Will post back if I once again find myself at the mercy of my own incompetence.
.dat, bash script, batch file, transient 3d
fluent issue in windows hpc pack 2012 r2 mosesHPC FLUENT 17 January 12, 2019 16:01
Write crashed .cas & .dat for Fluent yonpanman FLUENT 0 February 9, 2017 09:59
problems running fluent through matlab galapago FLUENT 1 October 10, 2013 10:20
Fluent Parallel Programing using Windows HPC 2008 santoshgoku FLUENT 22 February 23, 2013 01:56
