Defining Vacuum region in Parabolic Trough Collector. |
Osama Malik
Rep Power: 6 ![]() |
I want to define vacuum region in my space between absorber tube and glass cover for my Parabolic Trough Collector. In cell zone conditions, I've tried to set my required vacuum pressure through operating conditions window, but after this, it automatically sets this pressure to every other zone, which I don't want. I want vacuum in one region only in order to study conductive and radiative heat transfer in vacuum region. Kindly help.
Joshua
Rep Power: 12 ![]() |
You cannot define a vacuum region in Fluent. Fluent requires that there be domain (fluid or solid) between two surfaces for them to exchange heat.
You can work around this issue by meshing a fluid domain between the two surfaces you want to exchange heat, and then set the thermal conductivity of the fluid medium to a very low number and fix its velocities such that it is quiescent (remove effects of natural circulation). Setup the radiation problem (eg S2S, DO) and compare the fluxes due to radiation to the total heat flux through the surface. If the "fluid" region is still and a low enough thermal conductivity, this fraction should be close to 1. |
#3 | |
Osama Malik
#4 | |
Osama Malik
Remember, if I put absorber outer wall shadow to zero heat flux, while applying constant flux to absorber outer wall, I the conduction in vacuum (air for now) just vanishes. |
#5 | |
Joshua
Osama Malik
https://ibb.co/1rtvgFC
https://ibb.co/PMVF3fR https://ibb.co/rHcjdKF https://ibb.co/64dYRLv These are the images describing my fluid flow region (annular), absorber tube, vacuum region and glass cover in sequence. I know how to set up the vacuum region (using low conductivity for air), I just need to know how can I simulate the below mentioned case. "The flux should be applied on absorber tube outer wall, which would result in gain of fluid temperature inside me fluid domain. Also I want to simulate the heat transfer through absorber outer wall and vacuum region through conduction (I know it would be very little), the radiation heat transfer between absorber outer wall and glass inner wall and then finally radiation + convection heat transfer through glass outer wall to ambient (for which I have to use Mixed thermal B.C)" |
Joshua
Can you attach the photos directly to your reply? The hosting site is blocked for me.
Osama Malik
#9 |
Osama Malik
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
Defining wall boundary region | saleem | Siemens | 3 | August 31, 2005 03:58 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
