Matlab-Fluent Interfacing
Like Tree1Likes
  • 1 Post By ATIKADAR
Old   October 14, 2019, 17:08
Default Matlab-Fluent Interfacing
Amitav tikadar
ATIKADAR is on a distinguished road
I am trying to interfacing between Ansys Fluent 2019R2 and Matlab. I can run my Fluent simulation via Matlab. Now I am trying to calculate mass weighted average temperature of a volume and I have used this Matlab command
iFluentTuiInterpreter.doMenuCommandToString('repor t volume-integrals mass-avg (channel) temperature n')
This code can measure the temperature and can print the value in Matlab command window. But now I want to save this value in another variable so that I can use this number in post-processing. I am trying to use this command
iFluentTuiInterpreter.doMenuCommandToString('defin e variable pick report volume-integrals mass-avg (channel) temperature n')
but its not working. Can someone please help?
Thank you.
ATIKADAR is offline   Reply With Quote
Old   October 15, 2019, 01:05
Svetlana Tkachenko
Svetlana is on a distinguished road
Would you like to set fluent to write this value to a file, and then read it in matlab? Or this would be bad for your case.
Svetlana is offline   Reply With Quote
Old   October 16, 2019, 18:03
Amitav tikadar
I am trying to directly read and store this value in Matlab.
Svetlana likes this.
Old   October 16, 2019, 19:52
Svetlana Tkachenko
If you tried to do this through an external file, would it work at all, or would it create issues with the timing?
Old   October 16, 2019, 23:35
Amitav tikadar
I think external file would also work but since I am trying to combine few other software, it might slowed down the simulation. Anyway I already solved the issue. My code is something like this-
x=iFluentTuiInterpreter.doMenuCommandToString('rep or t volume-integrals mass-avg (channel) temperature n'); %it will save temperature as a string called x
y=char(x); % convert x into a character
Then I split the character and finally convert the appropriate character into a number.
Thank you.
fluent, matlab, matlab coding
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
linking matlab and fluent Nair FLUENT 23 January 12, 2020 19:55
How To Make MATLAB Apps For Fluent behest FLUENT 0 March 3, 2014 08:00
Creating UDF file in MATLAB for Fluent ppa381 Fluent UDF and Scheme Programming 1 October 10, 2013 10:27
Matlab for UDF's in Fluent tejasvikrishna FLUENT 1 September 9, 2010 08:28
