Turbulent compressible flow in a pipe with diffuser and nozzle
Like Tree1Likes
  • 1 Post By sufjanst
Old   October 8, 2019, 00:45
Default Turbulent compressible flow in a pipe with diffuser and nozzle
Denis
denispansolin is on a distinguished road
Hello everyone, I am trying to simulate turbulent compressible flow in a pipe with variable geometry (diffuser and nozzle). I am using air as the fluid (ideal gas). My mesh and geometry images are attached. The boundary conditions I have tried are:
1. Velocity inlet-pressure outlet
2. Pressure inlet-pressure outlet
3. mass flow rate inlet- pressure outlet
In all cases I am having same problem, that my flow (velocity) at the entrance of diffuser (exit from channel), the velocity contours goes up or down, not symmetric. ( I have attached the figure of the problem for better understanding). I am using coupled solver.
I am not able to figure out if its a mesh issue or somewhere I am missing something in setting up the problem.
It would be great if anyone can help me. Please.
Thank you.
denispansolin is offline   Reply With Quote
Old   October 8, 2019, 04:20
sufjanst is on a distinguished road
Did you specify the right Rotation-Axis Direction in your Cell Zone Conditions -> <fluid> ?
It is set to Z = 1 by default, your rotation axis is at X = 1. That can have an effect on the solution depending on your Boundary Conditions.
Greets
sufjanst
denispansolin likes this.
sufjanst is offline   Reply With Quote
Old   October 8, 2019, 14:15
Denis
Hey sufjanst I did what you said but I still have the same problem.
Diffuser reversed flow macdhui FLUENT 4 October 8, 2015 05:48
Swirling Flow through nozzle and diffuser, NonlinearKEShih model Phil_ OpenFOAM Running, Solving & CFD 0 July 10, 2014 05:04
Supersonic Inlet for a Compressible Flow in a Nozzle Daco FLUENT 8 November 8, 2012 04:34
Different flow patterns in CFX and Fluent avi@lpsc CFX 6 April 17, 2012 02:22
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 07:12
