Defining the thermal conductivity in a Solid-Solid interface
Like Tree1Likes
  • 1 Post By MKuhn
Old   October 3, 2019, 19:28
Default Defining the thermal conductivity in a Solid-Solid interface
Daniel
dsaen is on a distinguished road
I have a transient model with a Solid-Solid interface for which I know the thermal contact conductance coefficient.
żIs it possible to define the heat flow between solids using a convection-like formulation?
dsaen is offline   Reply With Quote
Old   October 7, 2019, 09:13
Default In newer versions yes
Moritz Kuhn
MKuhn is on a distinguished road
If you defined it as "Coupled Wall", that means you have wall and wall-shadow pair - yes. Then it is like in the attached picture and you can set the contact resistance in m² K /W.
In older versions of flunet you have to deal with a workaround defining an additional wall thickness between your solids which acts like an insulation.
8cold8hot likes this.
MKuhn is offline   Reply With Quote
Old   October 8, 2019, 12:32
Daniel
-- Never mind the comment below, it seems that the Contact Resistance option is only available with the Solidification model --
Are you aware of when they added this option (I have ANSYS 19)?
I do have a 'Coupled Wall', but I dont see that option. Am I doing something wrong?
Old   October 9, 2019, 03:55
Moritz Kuhn
Yes this is true
I do have a 'Coupled Wall', but I dont see that option. Am I doing something wrong?--
Maybe I was wrong and this option exist longer and I don't saw because I didn't use the Solidification model.
Try to switch on the solidification model. If you define the melting temperature in the material properties far away from your operation conditions, it will not affect the solution. Then try to define a large contact resistance and see if it works. In this case fluent consider also the thermal conductivity of the fluid enclosed between your solids.
Then try to do it with the proposed workaround. Define a certain wall thicknes which corrosponds to your
[contact resistance] = [wall thicknes / thermal conductivity of the solid]
Then compare the results. I'm curious about it.
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
IAPWS water properties + orthotropic thermal conductivity Chander CFX 1 February 29, 2012 18:26
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
