Book recommendation for pipe flow having incomprehensible fluid in ANSYS Fluent |
September 27, 2019, 03:04 |
Muhammad Rameez ud din
Rep Power: 6 |
Hi
I am doing project on ANSYS Fluent simulations on natural flow circulations in Solar-evacuated tube coupled with compound parabolic concentrating collector.please see attachment. I am facing problem in setting Solver properties either it should be pressure based or density based, and problem in boundary conditions. Kindly can anyone recommend me a very relevant book? it will help me to setting suitable physics. THANKS; |
September 27, 2019, 03:44 |
Lucky
Rep Power: 66 |
Try pressure-based.
Both work, but pressure-based is just way easier to set up, supports more models, and is more suitable anyway. |
September 27, 2019, 04:43 |
Rep Power: 6 |
Thank you. i will consider pressure-based. can you please recommend a good fluent book too? because i am having problems for setting appropriate boundary conditions.
September 27, 2019, 05:24 |
Alexander
Rep Power: 34 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Update failed for the solution component in fluid flow (Fluent) | delxysic | FLUENT | 1 | August 3, 2016 03:22 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Comparison between Solidworks Flow Simulation and Ansys Fluent | Bruce828 | Main CFD Forum | 5 | February 23, 2013 10:13 |
