Temperature falls below initial condition
Like Tree1Likes
  • 1 Post By MKuhn
Old   August 30, 2019, 08:46
Default Temperature falls below initial condition
Dnyanesh Mirikar
DnyanMiri is on a distinguished road
I'm using DPM method for mist cooling in rectangular channel. I set up model then initialize, patch initial temp and run calculation. Result is that temp falls below operating condition/initial temp. what could be the reason behind it?
But when I run same setup for air flow without using DPM, I get expected results and temp doesnt fall below atmospheric temp.
I have checked following things
-Operating temp in boundary conditions 298.15 K
-patch 298.15 K to zone to apply initial condition.
-ever other temp while applying boundary condition is greater than 298.15 K
I'm attaching screenshot of temp counters from DPM.
Please help me out, any kind of help is greatly appreciated.
DnyanMiri is offline   Reply With Quote
Old   September 2, 2019, 05:07
Moritz Kuhn
MKuhn is on a distinguished road
I think that it is what you have to expect. If you spray water droplets in an air flow, then the water will evaporate, which needs heat, therefore the temperature of the air decrease.
DnyanMiri likes this.
MKuhn is offline   Reply With Quote
dpm, setup fluent, temperature bc, temperature drop
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 10:10
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
