Measuring Radiaiton from a Flame
Like Tree5Likes
  • 1 Post By timotie87
  • 1 Post By LuckyTran
  • 2 Post By LuckyTran
Old   August 9, 2019, 18:28
Default Measuring Radiaiton from a Flame
Tim
timotie87 is on a distinguished road
I've seen a few papers talk about how ‘Incident Radiation’ or ‘Surface Incident
Radiation’ that is available as a field variable from Fluent is not the measurement one would want to use to obtain how much radiaiton a flame is giving off. For example, if I wanted to make a virtual radiometer in Fluent, what variable should I check over a small area to see what the incoming radiaiton is from a large fire?
Svetlana likes this.
timotie87 is offline   Reply With Quote
Old   August 9, 2019, 18:32
Svetlana Tkachenko
Svetlana is on a distinguished road
Which papers?
Svetlana is offline   Reply With Quote
Old   August 9, 2019, 18:35
Tim
http://cdmbuntu.lib.utah.edu/utils/g...ename/2387.pdf
"One should note that the ‘Incident Radiation’ or ‘Surface Incident
Radiation’ that is available as a field variable from the CFD
software is not the radiation intensity that is of interest.
Manipulation of the field variables is required to obtain the proper
value for post-processing."
Old   August 9, 2019, 18:41
Tim
I am trying to compare my CFD data for a large flare simulation with experiment. This includes calculating the radation to several remote targets (radiometers) around the fire at various distances. What variable should I monitor or compute to determine the radiation from the fire to the targets?
Old   August 12, 2019, 11:01
Lucky
If you are using a virtual radiometer, then surface incident radiation is the variable you want because you are not measuring how much radiation the flame is producing, but how much radiation arrives at your meter.
LuckyTran is online now   Reply With Quote
Old   August 12, 2019, 16:00
Tim
Is there a tool to create "virtual radiometers"? Right now I'm just creating small square plane surfaces within my domain and preforming surface integrals etc. Can I not compare the incident radiation values before and after the flame is present?
Old   August 12, 2019, 17:28
Lucky
There isn't a tool. You have to create points/surfaces like you are doing. It's not important to replicate the shape of a radiometer. Actually the radiometric principle is to measure the radiant flux and the radiometer device is trying to mimic your small square that you are creating.
It's fine to compare incident values before and after the flame, because that's what you would do with a radiometer anyway.
Svetlana and timotie87 like this.
fire, flare, fluent, radiation
Difficulties with premixed laminar methane flame in openFoam DustExplosion OpenFOAM 16 August 9, 2019 06:31
Flame kernal and flame propogation daizy EnSight 5 May 17, 2017 11:15
Initializing the flame for 1D premixed flame test case R.Mah OpenFOAM Running, Solving & CFD 1 January 11, 2017 09:44
calculate flame speed using reactingFoam IColin OpenFOAM Running, Solving & CFD 0 February 4, 2014 16:14
premixed flame modeling problem peiyong wang CFX 1 July 18, 2008 13:02
