July 28, 2019, 10:56 |
Time averaged velocity contour plots
Saurabh Kurmi
Hello everyone!!
I am doing a transient analysis in Ansys fluent. I want to get the time averaged velocity contour. I have enabled the data sampling for time statistics but confused about what to put in sampling interval?? |
July 29, 2019, 03:00 |
Svetlana Tkachenko
Rep Power: 15 |
Sampling interval of 1 second means that the variable is measured every 1 second.
For example, with a time step of 0.1 seconds, you have these results in a point: a1, a2, a3, a4, a5, a6, a7, a8, a9, a10, a11, a12, a13, a14, a15, a16, a17, a18, a19, a20 They correspond to these time values: 0.1s, 0.2s, 0.3s, 0.4s, 0.5s, 0.6s, 0.7s, 0.8s, 0.9s, 1s, 1.1s, 1.2s, 1.3s, 1.4s, 1.5s, 1.6s, 1.7s, 1.8s, 1.9s, 2s With a sampling interval of 0.1s you will get the average as sum(a1, a2, a3, a4, a5, a6, a7, a8, a9, a10, a11, a12, a13, a14, a15, a16, a17, a18, a19, a20) / 20 With a sampling interval of 0.2s it only takes every second value, sum(a2, a4, a6, a8, a10, a12, a14, a16, a18, a20) / 10 With a sampling interval of 1s it only takes one value every second, sum(a10, a20) / 2 |
July 29, 2019, 13:03 |
Lucky
Rep Power: 66 |
The sampling interval is not in seconds, it's time-steps.
July 29, 2019, 20:40 |
Svetlana Tkachenko
Rep Power: 15 |
Thank you for the correction, LuckyTran
In this case here is the updated example: Sampling interval of 1 means that the variable is measured every 1 step. For example, with a time step of 0.1 seconds, you have these results in a point: a1, a2, a3, a4, a5, a6, a7, a8, a9, a10, a11, a12, a13, a14, a15, a16, a17, a18, a19, a20 They correspond to these time values: 0.1s, 0.2s, 0.3s, 0.4s, 0.5s, 0.6s, 0.7s, 0.8s, 0.9s, 1s, 1.1s, 1.2s, 1.3s, 1.4s, 1.5s, 1.6s, 1.7s, 1.8s, 1.9s, 2s With a sampling interval of 1 you will get the average as a mean of all points: sum(a1, a2, a3, a4, a5, a6, a7, a8, a9, a10, a11, a12, a13, a14, a15, a16, a17, a18, a19, a20) / 20 With a sampling interval of 2 it only takes every second value, sum(a2, a4, a6, a8, a10, a12, a14, a16, a18, a20) / 10 With a sampling interval of 10 it only takes one value every ten steps meaning every second, sum(a10, a20) / 2 |
July 30, 2019, 12:31 |
Saurabh Kurmi
Thanks for all the replies.
I am performing the simulation of flow over a circular cylinder. I have to get the average velocity contour.I have given 1000 time steps with time step size 0.1 sec.What value of sampling intervel should i give?? |
July 30, 2019, 20:32 |
Svetlana Tkachenko
Rep Power: 15 |
1. "To do what you wrote you need sample interval = 1. This, btw, is always your best choice if you don't know what you're doing." (link)
In my experience another non-1 sampling interval was useful once when I wanted to compare with experimental data in which the lab recordings were sampled with a different frequency than my time step in ansys fluent. 2. Please also understand that you need to time average your data after the flow has finished developing. After you start your simulation it may take a while to settle. Adding a monitor point and watching its behaviour can be a good way to know when to begin your averaging. There is a plot about this here, and in this example they need to average after 0.03s. |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 22:00 |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 10:08 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 06:28 |
How to export time series of variables for one point? | mary mor | OpenFOAM Post-Processing | 8 | July 19, 2017 11:54 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
