Thermal boundaray conditions
Like Tree2Likes
  • 1 Post By intied
  • 1 Post By AlexanderZ
Old   July 27, 2019, 17:04
Question Thermal boundaray conditions
Edwin P
intied is on a distinguished road
I have a long duct opened at atmospheric pressure. I want to model a small section near to the end of the duct which generates heat. I have transient measurements of temperature at the beginning and at the end of the that section. At time t=0, all the system is at ambient temperature.
Should I use both the inlet and oultlet temperature measurements of my sections as a boundary conditions in Ansys Fluent?
Help me please,
Regards
Svetlana likes this.
intied is offline   Reply With Quote
Old   July 29, 2019, 01:48
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
from my point of view it depends on the goal of your simulation.
Make a decision -> what you want to simulate, then put boundary conditions
best regards
AlexanderZ is offline   Reply With Quote
Old   July 29, 2019, 02:52
Svetlana Tkachenko
Svetlana is on a distinguished road
Why is the temperature transient? Is this an externally imposed boundary condition in the experiment?
Svetlana is offline   Reply With Quote
Old   July 29, 2019, 11:53
Edwin P
The temperature increase inside the duct is due to a solid with internal heat generation. I added a source term and I want to model its transient temperature profile
Old   July 29, 2019, 13:01
Lucky
You can't impose an outlet temperature, not that you would need to, anyway. You would just use pressure outlet or outflow BC or something.
Just make sure you have the right inlet conditions and whatever else you need for your simulation. I can't follow what you want to do with heat generation and an inlet temperature.
Old   July 29, 2019, 16:18
Edwin P
Thank you.
In fact, I am using pressure inlet and pressure outlet as boundary conditions. But, I am not sure if I have to use the transient temperature profile in the "Thermal" tab of those boundary conditions.
By other hand, I have a small solid which generates heat. I want to model its transient temperature.
Old   July 29, 2019, 19:25
Edwin P
I have a small solid which generates heat due to joule effect. Therefore, near to that soild, the ambient temperature changes.
Thank you
boundary conditions, temperature
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Thermal Boundary conditions in natural convection problem ekha FLUENT 1 June 12, 2019 08:39
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
